2001 Ford Escape
Lid109
Member - Posts: 6
Posted: August 01, 2004 at 6:24 PM / IP Logged
Looking for the full wireing information on this vehicle.  Is it the same as 2002 or 2003?  I'll need everything.
-Ian
diabloed
Copper - Posts: 133
Posted: August 01, 2004 at 10:34 PM / IP Logged
12volts RED / lt blue (10A)    +   ignition harness
Notes: This wire is rated at 10 amps only. If installing any system with high current outputs, go to battery for 12v.
Starter tan/lt blue    +   ignition harness
Ignition lt GREEN/ purple    +   ignition harness
Accessory BLACK/ lt green    +   ignition harness
Power Lock pink/white    -   DKP or 26 pin plug @ GEM
Notes: Lock requires a negative trigger thru a 1,000 ohm resistor. Unlock is a negative trigger. Must use relay on both.
The GEM (generic electronic module) is behind the center console on the floor. Pull off the black panel to the right of the gas pedal, there will be carpet covering it. The plugs face the driver side of the vehicle.
Power Unlock same wire
Lock Motor pink/black      DKP or 26 pin plug @ GEM
Notes: The GEM (generic electronic module) is behind the center console on the floor. Pull off the black panel to the right of the gas pedal, there will be carpet covering it. The plugs face the driver side of the vehicle.
Unlock Motor RED / orange      DKP or 26 pin plug @ GEM
Parking Lights+ brown      drivers kick panel
Parking Lights- BLACK/ lt green      column or 22 pin plug @ GEM
Door Trigger PURPLE / lt green    -   cluster or 22 pin plug @ GEM
Dome Supervision lt GREEN/ black      drivers door harness
Notes: This wire rests at ground with the doors closed, and it is an open circuit with the drivers door open. Use a relay to interupt this wire to turn on the dome light.
Hood Pin PURPLE / orange    -   pin sw or 22 pin plug @ GEM
Factory Alarm Arm WHITE/ purple or lt GREEN/ black   -   DKP or 26 pin plug @ GEM
Factory Alarm Disarm blue/lt green    -   DKP or 26 pin plug @ GEM
Tachometer
Notes: On the ZETEC motor use GREEN/ purple or lt GREEN / WHITE at the coil pack. The Duratec motor has a coil for each cylinder, go to any one and use the wire that is NOT WHITE/ purple.
Brake Wire lt green    +   brake pedal switch
Horn Trigger yellow/lt green    -   steering column
Notes: May be in the SRS harness. Use a meter to test to avoid setting any codes or deploying the airbag.
Speed Sense gray/black      cruise servo on pass fender
Wipers blk/pnk(L),blu/org(H    +   steering column
LF Window up/dn wht/blk - red    A   driver window switch
RF Window up/dn tan/lt blu - wht/yel    A   driver kick panel
LR Window up/dn yel/blk - RED / blk    A   driver kick panel
RR Window up/dn gry/org - yel/lt blu    A   driver kick panel
Sun Roof open/close red - org      in front of sunroof
Sun Roof Limit/close ORANGE / white      in front of sunroof
Immobilizer Bypass Module: Required: Yes Type: SecuriLock Part #: 555S, 556U, or 555U
Notes: Use the BLACK/ pink (+) key sense wire at the ignition harness to interrupt the blue wire on the 555S or 555U so that when the key is inserted to do take over the vehicle does not see two transponders at the same time. Refer to DirectFax document 1079 for wiring information.
Radio 12v ORANGE / lt green    +   radio harness
Radio Ground black    -   radio harness
Radio Ignition yellow/black    +   radio harness
Radio Illumination lt blue/red    +   radio harness
LF Speaker +/- org/lt grn-lt blu/wh   +,- radio harness
RF Speaker +/- wht/lt grn - grn/org   +,- radio harness
LR Speaker +/- tan/yel - gry/lt blu   +,- radio harness
RR Speaker +/- org/red - brn/pnk   +,- radio harness
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
