questions about aps 786 RS
c0wb0yup
Posted: August 04, 2004 at 12:27 AM / IP Logged
I bought an Audiovox Prestige RS model aps 786.  I had no owners manual in the box ( although I did get the Installation Manual) and the install shop doesn't know where it is.  I found a PDF Owners Manual file online for the aps 785.  Question 1:  What are the differences between the 785 and 786 if any?    Question 2:  While the engine is running under it's own power, can I switch to "remote start" mode without shutting off the engine?  (useful for those quick trips at the convenience store while kids sit in the truck).  I am installing this RS unit in a 2002 Dodge Ram.  No questions about install, found plenty of info using the handy search feature.
Thanks in advance for your replies.
c0wb0y
draasch
Gold - Posts: 2,172
Posted: August 04, 2004 at 12:33 AM / IP Logged
dont know about the differences, i would think it has a pit stop mode. i know that the Omega Max does................
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
misterjimbo
Silver - Posts: 535
Posted: August 08, 2004 at 8:59 PM / IP Logged
no big difference between the two. The "pit stop" mode he was talking about will only work if the installer hooked up a tach wire. You activate it by pressind the remote start button twice
