Remote Start on '95 Caprice
weatherly
Member - Posts: 13
Posted: August 05, 2004 at 11:06 PM / IP Logged
What's going on ya'll? I recently bought a Prestige APS 786 Remote Car Starter, it came with instructions but I'm having trouble with it. It came with the brain, antenna, siren, input/output harness, power harness, LED, valet switch, control switch, shock sensor harness, door lock harness, 2-stage shock sensor, starter inhibit relay and socket, 2 30-Amp in'line fuse holders w/ fuses, and pin switch. Now I'm a beginner so I'm kind of overwhelmed here, I can do car stereo but this is a whole different thing. Where exactly would you guys start? If you could even give me a walk-through I would appreciate that. I'm new to the game, so I'm trying to add some more notches on my belt.
Success Follows Struggle
sroth140
Silver - Posts: 513
Posted: August 05, 2004 at 11:30 PM / IP Logged
get a DMM and test for the wire.  usually the installation manual tells you how to test for them.  youll probably need to search this forum for VATS also.
MECP certified installer
kkeeni
Member - Posts: 20
Posted: August 06, 2004 at 12:34 AM / IP Logged
this may help.12v-red ,ignition-pink ,starter-yellow ,accessory-orange-ign harn,parking lights 12v + brown-at  headlight switch,brake-white 12v+  above brake pedal,tach-white-at coil,lock-lt.blue\ unlock black- both in drivers kick, trunk-BLACK/ white-at trunk switch 12v,horn -black-steering column-neg trigger .       goodluck, and always test your wires first
weatherly
Member - Posts: 13
Posted: August 06, 2004 at 6:56 PM / IP Logged
Thanks guys, I'll get a multimeter this weekend and get started.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
