vats bypass
ShaunD912
Copper - Posts: 140
Posted: September 17, 2002 at 11:18 AM / IP Logged
Hello,
I am planning to install an add on remote starter in a 95 or 96 (can't remember) Impala SS.  It has the vats security system on it.  I was planning to use a relay and resistors.  I know to check the resistance of the key.  My question is in wiring the relay.  Ok, here's what I got:
85 - remote start output
86 - 12v
87a - switch side of vats wire
30 - starter side side of vats wire
87 - ?
I know i need to put the resistor on the 87 pin.  The only thing I was wondering is if it's resistance to ground or 12v?  How do I wire pin 87?
Also does anybody know what color the vats wire is in this vehicle.
Thanks.
Platinum - Posts: 12,488
Posted: September 17, 2002 at 3:14 PM / IP Logged
  • 85 :  GROUND OUT WHEN RUNNING WIRE from alarm
  • 87 : Uncut wire from the two VATS wires with resistor pellet
  • 86 : Primary Ignition ( NOT CONSTANT )
  • 30 : Keyside of VATS wire
  • 87a: Computerside of VATS wire
Here's the diagram if you need more help: https://www.the12volt.com/uploads/files/GMVatsPassKey.gif
ShaunD912
Copper - Posts: 140
Posted: September 17, 2002 at 10:05 PM / IP Logged
thanks velocity
Posted: September 18, 2002 at 5:20 AM / IP Logged
No problemo vats bypass -- posted image.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
