How many sensors on output?
spokman
Copper - Posts: 75
Posted: August 13, 2004 at 7:53 PM / IP Logged
How many sensors can you connect to the + output of the shock sensor before it will draw to many amps? Would 4 sensors be enough to burn up the 12v + circuit? Should a relay be used? Thanks for the help!
auex
Platinum - Posts: 5,041
Posted: August 14, 2004 at 1:34 AM / IP Logged
You should never connect power or ground for additional sensors to the original sensor. The only thing that should go to the original sensor is the trigger wires.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
spokman
Copper - Posts: 75
Posted: August 14, 2004 at 2:40 PM / IP Logged
Thanks! Wish the manuals that came with these things gave you important information like that.
