2000 Dodge intrepid door lock options
johngianni
Member - Posts: 10
Posted: August 17, 2004 at 7:36 AM / IP Logged
I have a 2000 Dodge intrepid, I am installing a ProLine REC11 Keyless Entry from Omega..
I had planned on the Single wire install with two resistors and two relays..
Then when I got on this site (which is great) I found on the wiring list for the intrepid that there is a
Drivers Lock
Drivers Unlock
Passanger Unlock
At the BCM.
2 questions
Where/what is the BCM
and   Is this positive pulse like the single wire.
I guess one more question is which is the best way to go,
My original plan or use the wires at the BCM?
Thanks for any help....
JohnG
raydawg357
Silver - Posts: 769
Posted: August 17, 2004 at 8:32 AM / IP Logged
The wire you are looking for is located to the rear of the fuse box.  The lock and unlock MOTOR wires are at the BCM.
 WHITE/ green  +  back of fusebox
Notes: Locks are positive trigger through resistors. Use 2.7K (2700) ohms for lock and 620 ohms for unlock.
Do it right the first time
johngianni
Member - Posts: 10
Posted: August 17, 2004 at 8:41 AM / IP Logged
Thanks for the quick response!
Looks like I should go with my original plan to use the single wire..
Just a quick question then.. The Motor wires at the BCM, can you trigger those with relays? And would this need a +12 to actuate the motors?
I think I'll go with the GREEN / WHITE single wire method, but was just wondering..
Thanks again for the help..
JohnG
raydawg357
Silver - Posts: 769
Posted: August 17, 2004 at 8:47 AM / IP Logged
Do not use the motor wires,  you will fry it.  use the lock and unlock wires
johngianni
Member - Posts: 10
Posted: August 17, 2004 at 8:51 AM / IP Logged
No problem. Loud and Clear :)
I didn't think thats what I wanted..
Thanks again for the help!!
2000 Dodge intrepid door lock options -- posted image.
JohnG
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
