2004 silverado by-pass kit
woosh
Member - Posts: 14
Posted: August 27, 2004 at 4:44 PM / IP Logged
I am installing a valet 562T in a 2004 silverado and I was just wondering what is the best and easy to install security bypass kit available.
kgerry
Platinum - Posts: 3,455
Posted: August 27, 2004 at 6:28 PM / IP Logged
you'll need a 555L for bypass and a 456G for data... i rely on DEI modules for their reliability.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
NowYaKnow
Gold - Posts: 1,217
Posted: August 27, 2004 at 8:58 PM / IP Logged
I would say a PLDATA is the easiest to install and so far the most reliable that I've seen for bypassing passlock 2. For the locks a GMDL4 would be a good choice.
Mike
woosh
Member - Posts: 14
Posted: August 27, 2004 at 10:04 PM / IP Logged
Thank's guys, I'll give it a try.
lspker
Silver - Posts: 503
Posted: August 27, 2004 at 10:50 PM / IP Logged
We just did one, tried three different "data" modules, and one hard wire programmable.  Had to go to a low-tech dial in the resistor type to get it to work.
kgerry
Posted: August 28, 2004 at 3:29 PM / IP Logged
i've done loads of 03 and 04 CK's and always used the 555L and never had a problem with them.... PLDATA works too but because it doesnt actually broadcast a code the security light on the dash stays on often....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
extreme1
Silver - Posts: 1,070
Posted: August 28, 2004 at 7:03 PM / IP Logged
GMDAA is what I use, it does most GM's with OBD-II for passlock and PK3 and locks/trunk/alarm on vehicles that use databus
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
