1998 Blazer w/ Passlock?
Mattthew278
Copper - Posts: 52
Posted: September 02, 2004 at 4:25 AM / IP Logged
My friend and I are about to start installing a remote start/keyless entry module into his blazer.  We have seen on here that his car is protected by passlock and requires a bypass module.  Could someone explain exactly what passlock is?  Can it only be bypassed with a special module?  Is this module readily available at a best buy or circuit city?  Any help is greatly appreciated.
mo12v
Posted: September 02, 2004 at 9:01 AM / IP Logged
The Passlock System uses what is known as a"Hall Effect Sensor" to send a resistor code to the Passlock Module.This resistor code is activated when the key physically rotates a magnet in the ignition switch.In some vehicles the code is activated when the ignition switch is turned to the run position, while on others it is not activated until the switch is in the start position.
YES..........U do need a By-Pass Module
We use Omega #Pass2, or #DB-PLDATA which ties into DATA wire(easier)
U can probably get it at the stores U mentioned..........But why not buy it at your LOCAL Stereo shop.......We all need the support
Constant 12 voltsRED & ORANGEIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightGRAY/BLACK (-)AT BODY BUSSED ELECTRICAL CENTER *
Trunk Pin SwitchN/A
Parking LampL BLUE (+)AT HEADLIGHT SWITCH **
Power LockL BLUEAT BODY BUSSED
Power UnlockWHITEELECTRICAL CENTER *
* Body Bussed Electrical Center Is Located Behind The Driver Dash Above The Driver Kick Panel. ** L BLUE (+) Wire For Parking Lights Is Also Located At The Body Bussed Electrical Center.  Positive Pulse Door Lock
Accessories
Window UpD\ D BLUE P\ L BLUE D\ D GREEN P\ L GREEN @ MAIN
Window DownF/ BROWN F/ TAN R/ VIOLET R/ VIOLET SWITCH
Ign Key WarnL GREEN (-)48 WAY CONN. NEXT TO STEERING COLUMN
Trunk Release
BLACK/ WHITE (+)
also BLACK at SWITCH (-)
ABOVE DRIVER KICK PANEL
OEM HornBLACK (-)48 WAY CONN. NEXT TO STEERING COLUMN
HeadlightsWHITE (+)AT BODY BUSSED ELECTRICAL CENTER *
OEM Alarm ArmN/ANO OEM ALARM PRESENT IN SCHEMATICS
OEM Alarm DisarmN/ANO OEM ALARM PRESENT IN SCHEMATICS
Reversal Rest At Ground Power Window Circuit Diagram. * Body Bussed Electrical Center Is Located Behind The Driver Dash Next To The Driver Kick Panel. Positive Pulse Trunk Release
Remote Start
Tach SignalWHITEAT POWERTRAIN CONTROL MODULE *
Ignition #2ORANGEIGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3WHITEIGNITION SW. HARNESS (TRANSMISSION)**
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightGRAY (+)AT SWITCH ON TRANSMISSION
Rear Window DefrostN/A
* Powertrain Control Module Is Located On The Passenger Side Of The Engine Compartment. ** WHITE Wire Is A Smaller Gauge Wire Than Other Ignition Circuits.  G.M. Passlock II
MO
xtremeaudio
Copper - Posts: 174
Posted: September 03, 2004 at 1:38 AM / IP Logged
 ALL YOU NEED DEI 555L COME WITH INSTRUCTIONS ESAY TO FOLLOWING
