adding a back up battery to Viper 591xv
Autosexual
Member - Posts: 47
Posted: September 04, 2004 at 11:50 PM / IP Logged
One more question to add to the other two I have:  where do you hook up the blue output trigger wire from a DEI back up batter to a 591xv alarm?  It says to the trigger input wire, but which one is that?
auex
Platinum - Posts: 5,041
Posted: September 05, 2004 at 12:00 AM / IP Logged
Yes, blue from backup battery to blue -instant trigger on alarm.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
RufNUSD
Copper - Posts: 184
Posted: September 05, 2004 at 12:01 AM / IP Logged
Buddy you dont have a security system. You dont have a trigger input. Sorry if you were uninformed.
Someone pass me that bottle.
auex
Posted: September 05, 2004 at 1:05 AM / IP Logged
Ah, that is right. The 591vx is just a remote start keyless not an alarm.
Teken
Gold - Posts: 1,492
Posted: September 05, 2004 at 3:45 PM / IP Logged
Regardless of that fact. That tiny DEI battery will not give you enough current to sustain the alarm for any reasonable amount of time.
Once you have upgraded the system. Go to the battery store and replace it with a 12 volt, 7.0 AH sealed gell, or sealed lead acid one.
They are aprox the size of a brick, and will supply enough current for many weeks. If you place them in parallel it will increase the current capacity.
Regards
EVIL Teken . . .
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
