99 vw beetle, remote start
bthurber
Posted: September 07, 2004 at 11:05 AM / IP Logged
so i just installed my second remote starter,
its in a 99 vw beetle. problem is that it cannot be started while locked or the alarm goes off. i do have a secuity bypass wire that i didnt hook up, since i was recently looking for WHT/BLU (from bulldogsecurity.com)
from 12volt.com i am now looking for BLK/BLU which says,
ignition power for factory alarm open w/ relay.
can somebody explain what this means ?
there are other similar stories i found in here, but none of them seemed to have a solid reply.
the 99 doesnt have the transponder, i would have though i could just connect the wire, presuming i could find it, do i need a relay?
thnx
kgerry
Platinum - Posts: 3,455
Posted: September 07, 2004 at 5:54 PM / IP Logged
****  A single pulse disarms the alarm, a double pulse will also unlock all the doors.  FOR REMOTE START: The vehicle can be remote started without disarming the factory alarm by using a relay to open the BLACK/ VIOLET wire (ignition sense) at the alarm module during remote start.  You will also have to run your remote starter's start output directly to the starter relay RED / BLACK on the back of the fusepanel to bypass the factory starter kill.
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
bthurber
Posted: September 08, 2004 at 6:12 AM / IP Logged
ok, sounds good.but i have some more questions, as i am noob.
1) is there a specific type or relay i will need, and where can i get one
2) does this mean that the alarm bypass wire from the remote start unit goes both to the relay and to the RED / black wire on the back of the fuse panel, or does the RED / black also need to be attached to the relay?
i suppose im not clear on what the starters start output is. could you explain that a little more. thanks for all your help.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
