viper 791remotestarter clutch bypass
ssspeardogg
Posted: September 13, 2004 at 7:03 PM / IP Logged
I have a 93 accord with a viper 791and i was wonering what color wires off the alarm,  and what color wires from the clutch.how i should wire a relay to bypass my clutch so the car will start without the clutch depressed.thanx.also i wired my tach wire all the way through the engine compartment because I didnt know where to put it in the car is there another location cause it dont look pretty>
RufNUSD
Copper - Posts: 184
Posted: September 13, 2004 at 11:09 PM / IP Logged
You are kidding I hope. I dont know the proper wire colors but if you insist on doing this you should goto the clutch and find the response on the wire when it is depressed. Use a relay off of the blu.wht wire on the brain and throw the appropriate polarity to it. I would reccomend as well a wire hooked up to the reverse lights (read. blk/wht) to prevent starts in reverse and also a switch on the same wire to prevent the damage that is bound to happen. A good measure as well is to tie in the ebrake sense to the same wire. Cheers.... Mel
Someone pass me that bottle.
xtremeaudio
Copper - Posts: 174
Posted: September 14, 2004 at 2:38 AM / IP Logged
ON HONDA CLUTCH HAVE 2 WIRE ONE OF THEM (-) AND ONE WATING FOR (-) WHEN THE CLUTCH IS PRESS DOWN  ON VIPER BLUE WIRE ON RELAY PACK HOOK UP TO DIODE THEN HOOK UP TO WIRE WAITING FOR (-) ON THE CLUTCH
