1999 camaro alarm problems
100na99
Posted: September 19, 2004 at 4:37 PM / IP Logged
Every time I lock my doors with the powerlock button or keyless remote the alarm will set and then after about 2 minutes the alarm will go off. Is there a way to deactivate the alarm so I can still use my keyless entry or can some tell me where to locate the shock sensor to adjust or deactivate it.
draasch
Gold - Posts: 2,172
Posted: September 19, 2004 at 6:37 PM / IP Logged
what brand of unit do u have??????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
100na99
Posted: September 19, 2004 at 10:29 PM / IP Logged
Its the factory alarm.
sroth140
Silver - Posts: 513
Posted: September 20, 2004 at 12:01 AM / IP Logged
sparkie
Platinum - Posts: 2,061
Posted: September 20, 2004 at 2:51 PM / IP Logged
The shock sensor is mountged above the passenger wheel well, under the trim panel covering your spare tire. There is a trim pot to adjust it's sensitivity on the sensor or just unplug it to make sure that it is the problem.
sparky
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
