key bypass for remote start
Installer001
Posted: September 19, 2004 at 6:53 PM / IP Logged
Does the 98 Accord requier a bypass for the remote starter...
I can only remote start the car with keys in the car. Defeats purpose rightkey bypass for remote start -- posted image...
Any diagrams or info would be helpfull
thanks
Teken
Gold - Posts: 1,492
Posted: September 19, 2004 at 6:58 PM / IP Logged
You will require a DEI 555U or similar bypass unit.
Honda
Accord
1998-2002
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   BLACK/ WHITE
IGNITION SWITCH HARNESS **
Ignition #1:
   BLACK / YELLOW
Ignition #2:
   YELLOW
Ignition #3:
Accessory:
   WHITE/ BLACK
Brake Light:
   WHITE/ BLACK
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
   BLUE
AT COIL MODULE
Parking Lights:
   RED / BLACK
AT FUSE BLOCK ON DRIVER'S SIDE
Headlights:
OEM Alarm Disarm:
   BLUE
INSIDE OF DRIVER'S DOOR
OEM Alarm Arm:
   BLUE/WHITE
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
   * This vehicle is equipped with a transponder immobilizer system; See Installation Note #144 - Bypassing Transponder Theft Systems.
Honda
Accord
1998-2002
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   WHITE
Starter Kill:
   BLACK/ WHITE
Ignition +12 Volts:
   BLACK / YELLOW
Dome Lights/Superv:
   BLACK/ WHITE (-)
4 PIN GREEN CONN. IN PASS FUSE BOX
OEM Horn:
   BLUE/GREEN (-)
IN STEERING COLUMN HARNESS
Power Lock:
   BLACK/ BLUE (-)
PASSENGER SIDE FUSE BOX**
Power Unlock:
   ORANGE (-)
Trunk Release:
   WHT/RED+
# PIN GRAY CONN. ABOVE DRIVER'S KICK
Alarm Input Wire:
   BLACK/ WHITE (-)
Notes:
** See Note#201 Negative Trigger Door Locks
xtremeaudio
Copper - Posts: 174
Posted: September 19, 2004 at 7:51 PM / IP Logged
you will need dei 556u that the most easy way for you to install
DEI 556U IS $19.95
http:///.com/dll?ViewItem&category=60203&item=5715048375&rd=1&ssPageName=WD1V
Installer001
Posted: September 20, 2004 at 4:52 PM / IP Logged
Thanks a bunch for your reply  much appreciated
