98 s-10 remote start, cranks, no fire
98onyxss
Posted: September 19, 2004 at 10:33 PM / IP Logged
I installed a remote start/alarm/keyless entry in my s-10. When i push the remote start it will crank, but it wont start. Besides the one yellow ignition wire, is there anything i am missing?
98 s-10 ss 4.3
drvnbysound
Silver - Posts: 289
Posted: September 19, 2004 at 10:49 PM / IP Logged
Assuming you are saying, that the truck turns over, however wont stay running? If thats the case, you need to connect the Tach wire from the alarm to the Tach circuit and program the alarm with that input. Hopefully, that will fix your problem. Good luck.
sroth140
Silver - Posts: 513
Posted: September 19, 2004 at 11:38 PM / IP Logged
what part did you use to interface with the passlock II immobilizer system the truck is equipped with?
MECP certified installer
lowfat
Member - Posts: 11
Posted: September 20, 2004 at 11:08 AM / IP Logged
go to this site on this page
Vehicle Wiring Information - up to 2000 the12volt
this tells you the diagram for the vehicle.you are missing the IGN & IGN2 wires
lowfat
Member - Posts: 11
Posted: September 20, 2004 at 11:13 AM / IP Logged
you have to program your alarm for TACH or VOLTAGE and make sure you hook up your by-pass module right.if its a DEI it tells you on the module.if you need more help e-mail me I have the same vehicle
98onyxss
Posted: September 20, 2004 at 8:13 PM / IP Logged
I have the tach hooked up, wire number 20, 4 in from the side. its white. I programmed the tach rate, the engine cranks, but it is like there is no spark, or no fuel. If, I have the Ign 1 and 2 hooked up wrong, would this cause that proble, and why? I dont have passlock, my keys are not vats, or the one with the chip in the head, so thats not my problem. Thanks
98onyxss
Posted: September 20, 2004 at 8:19 PM / IP Logged
wait....passlock is in the cylinder, not the key....right?
sroth140
Silver - Posts: 513
Posted: September 20, 2004 at 9:38 PM / IP Logged
i already said you have passlock. its in the key cly. but the 555L, install it properly, remote start the truck.
98onyxss
Posted: September 25, 2004 at 5:28 PM / IP Logged
okay, i got the 555L.  But still no start.
There are two yellow wires coming out of the collumn, one if you cut, the truck wont crank. thats the one i hooked the starter interupt to. The other if you cut, the truck will crank, but not fire, or fire and die. Thats the one i hooked up to the 555l. I am using a prestige aps786. I can start the truck by key, and remote start if the key in in the run position. but i still cannot remote start. I dont think the status wire on the 555l is hooked up right. does anyone know what the right connections are, or any kind of help at all. this is driving me insane.
craniumvibratio
Copper - Posts: 55
Posted: October 09, 2004 at 12:59 PM / IP Logged
if the 555l is hooked up right then you will have to check the status input. im not framiliar with the alarm you have but i know that you must have the status input connected. also you must hook up the third ignition the small white wire.
let me know how it goes
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
