98 civic remote start wiring
dstogsdill
Posted: September 23, 2004 at 2:32 PM / IP Logged
Does anyone know where to find a wiring diagram for a 98 honda civic that describes where to find the exact wires I need for remote start?  Anything would help.  Thanks
Donny Stogsdill
mo12v
Posted: September 23, 2004 at 4:31 PM / IP Logged
Constant 12 voltsWHITEIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK / YELLOWIGNITION SWITCH HARNESS
StarterBLACK/ WHITEIGNITION SWITCH HARNESS
Dome LightL GREEN/ RED (-)24 PIN BLUE CONN. TOP FUSE BLOCK *
Trunk Pin SwitchBLUE/BLACK (-)16 PIN BLUE CONN. BELOW FUSE BLOCK
Parking LampRED / GREEN (+)7 PIN GREEN CONN. AT FUSE BLOCK
Power LockGREEN / WHITE16 PIN BLUE CONN. BELOW
Power UnlockGREEN/ ORANGETHE FUSE BLOCK
Negative Pulse Door Lock Diagram. * W/Keyless- Removing Radio Will Interrupt Dome Light Circuit. Jumper Pin #8 (L GREEN/ BLACK) To Pin #14 (L GREEN/ RED) To Reconnect Domelight Circuit
Accessories
Window UpD\ RED / YEL P\ BLU/YEL D\ RED / YEL* P\ RED / YEL** @ MAIN SWITCH
Window DownF/ RED / BLU F/ BLU/ORG R/ RED / BLU* R/ RED / BLU**
Ign Key WarnBLUE/WHITE (-)IGNITION SWITCH HARNESS ***
Trunk ReleaseN/A
OEM HornBLUE (-)STEERING COLUMN HARNESS ****
HeadlightsRED (+)AT HEADLIGHT SWITCH
OEM Alarm ArmARMS THRU OEM REMOTEOR PASSIVELY
OEM Alarm DisarmDISARMS THRU REMOTEOR THRU OEM VALET SWITCH
* RED / YELLOW Wire On Both Rear Windows Changes Color To BLUE/RED Or YELLOW At Motor. RED / BLUE Wire On Both Rear Windows Changes Color To BLUE/WHITE Or RED At Motor. *** BLUE/WHITE Wire Changes Color To BLUE/RED. **** BLUE Wire Changes Color To GRAY.   Reversal Rest At Ground Power Window Circuit
Remote Start
Tach SignalBLUEAT TACH TEST CONNECTOR *
Ignition #2YELLOWIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryWHITE/ BLACKIGNITION SWITCH HARNESS
Neutral SafetyN/A
Brake LightGREEN / WHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightGREEN/ BLACK (+)14 PIN GRAY CONN. IN DR. KICK PANEL
Rear Window DefrostN/A
* Tach Test Connector (2 Pin WHITE Connector) Is Located On Driver Strut Tower.
MO
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
