remote start 2001 chevy silverado
revmatt99
Member - Posts: 28
Posted: September 23, 2004 at 3:10 PM / IP Logged
I have a 2001 chvy silverado.. i installed a omega crimeguard 533i3 in it with an omega rs6 remote starter. I bypassed the passlock with pldata. Everything works ok , except when i remote start the truck the heater / air conditioner fan wont blow until i put the key in and turn it. i need to hook up to the orange accessory wire i believe. can someone please help me. do i need diodes to do this? thanks in advance.
mo12v
Posted: September 23, 2004 at 4:27 PM / IP Logged
30 - 40 AMP SPDT Relay
If I remember ....There should be a ORANGE wire from RS 6 for Anti-Starter Grind.  U should be able to use that.  If not let me know
Pin 87 to 12 volts + constant
Pin 30 to ACCESSORY Wire Orange
Pin 85 to ORANGE wire from RS 6
Pin 86 to Constant
MO
jaurora
Silver - Posts: 429
Posted: September 24, 2004 at 1:19 PM / IP Logged
From personal experance this sounds like you have the wrong accesscory wire. The wire you are looking for is the accessory wire that operates the heater/ac controll.
Accessory:
ORANGE
IGNITION SWITCH HARNESS (HEAT/AC)
MECP certified (If it really means anything)
Jeremy
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
