Trunk Pin
thousandandone
Member - Posts: 31
Posted: September 27, 2004 at 6:31 PM / IP Logged
Hello,
On the wiring diagram for 91 Legend says
Trunk Pin ------ GREEN/ Black
however, when I connect this wire to the module ( Compustar CM3000 ) It could not Lock/Unlock the door , and the lifting up/down trunk on the remote. Anyone help please
Thank You
Autostar
mo12v
Posted: September 27, 2004 at 6:49 PM / IP Logged
The TRUNK Pin for Alarm is:
Trunk Pin SwitchGREEN/ BLACK (-)LEFT SIDE STEERING COLUMN - GREEN CON
The TRUNK RELEASE wire is:
Trunk ReleaseWHITE/ BLACK (+)AT RELEASE SWITCH
Positive Pulse Trunk Release
MO
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
