PT curiser factory disarm
swamprat323
Gold - Posts: 1,335
Posted: September 28, 2004 at 7:17 PM / IP Logged
The car is a 2004, The car dont have power locks or an alarm system but does have the sentry key. The car does have a remote to disarm the starter kill. does this mean there is a alarm system in but never had power locks installed, the parking lights dotn blink and the horn dont sound either. She does want a keyless entry in, but how would you disarm it. The wire guide says its a WHITE/ green wire, but that is the power unlock wire, if the car never had power locks will that WHITE/ green wire bee in there. if so my problem is solved but if its not in there how would you disarm it.
Another Question.
To be able to start the car you have to use the remote, if the battery died in the remote or the remote got damage how would you start the car, i went through the manural but nothing.
draasch
Gold - Posts: 2,172
Posted: September 28, 2004 at 7:48 PM / IP Logged
you will have to add the motors to the doors.......is there an LED at the bottom of the dash on the drivers side??????
if so,
its just a starter disable...i would remove it and start from scratch.....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
swamprat323
Gold - Posts: 1,335
Posted: September 28, 2004 at 7:52 PM / IP Logged
yes there is a red LED there, that was one thing i though of doing just take it out.
But just for the info how would u disarm it if the remote died for some reason.
draasch
Gold - Posts: 2,172
Posted: September 28, 2004 at 7:56 PM / IP Logged
there should be a button that you instert into the back of the LED. i think the unit is a brand called Silencer....its a dealer setup designed for mass installs......the owner may have not gotten the valet button...look in the glovebox......sometimes they come in a little case....
Good Luck
David
Ace Security
813-376-9778
Tampa
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
