1992 Ford Tempo GL 2 Dr Diagram
CarNut
Member - Posts: 22
Posted: September 30, 2002 at 12:54 PM / IP Logged
Could someone give me some pointers on this car, preparing to install a CS2015FM alarm/starter /door locks etc.....
Thanks A Million!
CarNut
Platinum - Posts: 12,488
Posted: September 30, 2002 at 9:39 PM / IP Logged
No pointer... straight forward installation. Here's the diagram if you need :
|              12V|yellow              |+  |ignition harness            |
|          STARTER|WHITE/ pink          |+  |ignition harness            |
|         IGNITION|RED / lt. green       |+  |ignition harness            |
|        ACCESSORY|gray / YELLOW         |+  |ignition harness            |
|       POWER LOCK|pink / YELLOW *1      |5wi|drivers kick panel          |
|     POWER UNLOCK|pink/green  *1      |5wi|drivers kick panel          |
| PARKING LIGHTS +|brown               |   |at switch or fuse box       |
|       HEADLIGHTS|RED / yellow          |+  |at light switch             |
|     DOOR TRIGGER|BLACK/ lt. blue      |+  |under dash light            |
|  TRUNK/HATCH PIN|BLACK/ pink (2 door) |-  |sw or light in trunk        |
|TRNK/HTCH RELEASE|purple / YELLOW       |+  |switch                      |
|       TACHOMETER|tan / YELLOW          |   |at coil                     |
|       BRAKE WIRE|RED / lt. green       |+  |at brake pedal switch       |
|     HORN TRIGGER|yellow/lt. green    |+  |at relay above fusebox      |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|yellow, wht/blk     |A  |in drivers door             |
|  RF WINDOW UP/DN|yel/wht - tan/blu   |A  |in drivers door or dkp      |
|  LR WINDOW UP/DN|gray/orn - yel/blu  |A  |in drivers door or dkp      |
|  RR WINDOW UP/DN|yel/blk - RED / blk   |A  |in drivers door or dkp      |
Notes:
*1  Door locks are positive (+) on the 2 door.  Use the same color wires as we list above.
CarNut
Member - Posts: 22
Posted: October 01, 2002 at 6:13 PM / IP Logged
Jeff,
 You are the man!!...
Thanks A Million..
CarNut
Posted: October 01, 2002 at 9:14 PM / IP Logged
No problemo... good luck
