2002 dodge Ram
jaurora
Silver - Posts: 429
Posted: October 11, 2004 at 8:58 AM / IP Logged
Can someone please help me out with the tech sheet for a 2002 Dodge ram 1500 w/5.9L engine.
Thans as always.
MECP certified (If it really means anything)
Jeremy
mo12v
Posted: October 11, 2004 at 9:04 AM / IP Logged
This is what I have:
Constant 12 voltsPINK/BLACK RED / WHITEIGNITION SWITCH HARNESS
Ignition 12 voltsBLUE 16 gaugeIGNITION SWITCH HARNESS *
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightBROWN (-)DRIVER A PILLAR (TECH NOTE)
Trunk Pin SwitchTHIS IS A PICKUP
Parking LampBLACK / YELLOW (+)AT RELAY BOX UNDER HOOD **
Power LockWHITE/ DARK GREEN14 PIN CONNECTOR IN DRIVER
Power UnlockSINGLE WIRE SYSTEMKICK PANEL ***
* USE THE SMALL GAGE BLUE WIRE! ** BLACK / YELLOW (+) At Relay Box Under Hood Or At Parking Light. *** WHITE/ DARK GRN Wire Must See Ground Through 820 Ohm Resistor For Lock And Ground Through 330 Ohm Resistor For Unlock.Alt: 220 Ohms. Confermed By More Than One Source The 220 Ohm Worked On Unlock.  Single Wire Resistor Door Lock Circuit
Accessories
Window UpD\ LT BLU P\ BRN/WHT D\ BLU/WHT P\ GRY/WHT @ DRIVER DOOR MODULE
Window DownF/ WHITE F/ VLT/WHT R/ RED / BLK R/ GRN/WHT M
Ign Key WarnBLACK/ DK GRN (-)IGNITION HARNESS
Trunk Release
OEM HornBLACK/ RED (-)STEERING COLUMN HARNESS
HeadlightsPURPLE / YELLOW (-)SEE TECH NOTES
OEM Alarm ArmLT GRN/ORANGEDRIVER KICK PANEL *
OEM Alarm DisarmSINGLE WIRE SYSTEM
*LT GRN/ORANGE-Arm/Disarm Must See A Ground Pulse thru a 1.5K Ohm Resistor To Arm/Lock and a Ground Thru A 550 Ohm Resistor To Disarm/Unlock Use Double Pulse Unlock.
Reversal Rest At Positive Power Window Circuit
Remote Start
Tach SignalTAN/REDIGNITION COIL
Ignition #2RED / WHITE 16ga*IGNITION SWITCH HARNESS(TRANS CON)
Ignition #3DARK GREENIGNITION SWITCH HARNESS (BLOWER)**
AccessoryBLACK/ WHITEIGNITION SWITCH HARNESS
Neutral Safety
Brake LightWHITE/ TANAT SWITCH ABOVE PEDAL
Reverse LightVIOLET/BLACK (+)64 PIN CONNECTOR UNDER HOOD***
Rear Window Defrost
* Also Has Been Noted As RED. **Ignition # 4 : ORANGE Ignition Switch Harness Air Bag Control Module. *** 64 Pin Connector Located On Firewall By Driver Fender VLT/BLK pin # B7
Transponder By Pass Circuit
If Key is GREY-Vehicle has Transponder, If Key is Black-Vehicle Does Not Have Transponder
Dome Light: Remove Support Handel Drivers Side Window 2 Screws,Remove Panel Behind Support.Dome Wires Are In A 12 Pin Connector Behind The Panel. Alt Door Triggers- Dr Front=TAN,Dr Rear= VLT/ORG @ Driver Kick Pass Front= TAN/RED, Pass Rear= TAN/YEL @ Pass Kick All (-) Diode Isolate
MO
jaurora
Silver - Posts: 429
Posted: October 11, 2004 at 9:08 AM / IP Logged
Wow,
Mo thanks for the fastest response I have yet to see.  Always appreaciated!
Jeremy
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
