2004 toyota camery
jay's detailing
Member - Posts: 24
Posted: October 11, 2004 at 9:52 PM / IP Logged
hello 2 all super installers out there in 12volt land, I'm in need of a wiring diagram 4 a 2004 or 2005 toyoa camery. I'm installing a prestige aps996a alarm remote start combo. any helpful info please sent it 2 me.. I thank u all much.  ~~~~~~~~~~~~~~~~~~~~~~~~Angel~~~~~~~~~~~~~~~~~~~~~~~~~
mo12v
Posted: October 11, 2004 at 10:00 PM / IP Logged
This is what I have:
Constant 12 voltsWHITE/ REDIGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ REDIGNITION SWITCH HARNESS
StarterBLACK / YELLOW AND BLACK/WHITE AT IGNITION SWITCH HARNESS *
Dome LightRED / BLACK (-)22 PIN CONN,TOP LEFT REAR OF ECU **
Trunk Pin SwitchGREEN (-)PIN 2 OF 12 PIN CONN.IN DR. KICK
Parking LampGREEN (+)PIN 19 OF 20 PIN CONN.BOTTOM FUSE BOX
Power LockBLUE / YELLOW12 PIN BLU CONN DRIVER KICK
Power UnlockBLUE20 PIN WHT CONN DRIVER KICK ***
* There Are Two BLACK / YELLOW Wires Please Check. ** ECU Located At Back Of Driver Side Fuse/Junction Block *** First Pulse Unlocks Driver 2nd Pulse Unlocks The Rest. Unlock Detection Wire Is GREEN
Negative Pulse Door Lock Circuit
Accessories
Window UpD\ GREEN P\ GRN/WHT D\ GRN/YEL P\ GRN/BLK @ MAIN SWITCH
Window DownF/ RED F/ RED / BLU R/ RED / YEL R/ RED / BLK
Ign Key WarnL BLUE (-)2 PIN CONN BEHIND IGN HARN CONN *
Trunk ReleaseWHITE/ BLUE (+)AT 12 PIN WHT CONN DR KICK #232
OEM HornGREEN/ BLACK (-)24 PIN CONN,LOW FRT OF JUNC/FUSE BOX
HeadlightsRED / YELLOW (-)AT HEADLIGHT SWITCH
OEM Alarm ArmWORKS WITH DOOR LOCKS
OEM Alarm DisarmWORKS WITH DOOR LOCKS
*NEG Pulse Before IGN (Remote Start) Will Disarm OEM Alarm
Reversal Rest At Ground Power Window Circuit
Reversal Rest At Ground Trunk Release Circuit. OEM Horn Wire: WHITE At Theft Deterrent E.C.U. OEM Alarm Hood Trigger:BLACK At Theft Deterrent E.C.U.
Remote Start
Tach SignalBLACK/ ORANGEGREY 22 PIN CONN RT OF STEER COLUMN
Ignition #2BLACK / YELLOWIGNITION SWITCH HARNESS *
Ignition #3
AccessoryBLUE/REDIGNITION SWITCH HARNESS
Neutral SafetyNON GROUNDING TYPE
Brake LightGREEN / WHITE20 PIN CONN,LOW LFT OF FUSE/JUNC BOX
Reverse LightRED / BLACK (+)20 PIN CONN,LOW LFT OF FUSE/JUNC BOX
Rear Window DefrostYELLOW /GREEN (-)8 PIN CONN,FRT RT OF FUSE/JUNC BOX
Immobilizer Bypass Diagram (Some Vehicles Reported W/O) Omega Part:DB-PKT NOT Compatible. Requires 3rd Key (PASS-4) * Cold Start Wire BLACK / YELLOW There Are Two BLACK / YELLOW Wires One Tests Like A Starter Wire The Other Like A Ignition ,Please Check.
MO
Platinum - Posts: 12,488
Posted: October 11, 2004 at 10:02 PM / IP Logged
2004 Information
2005 Information
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
