need diagram 96 ford windstar
tek1000
Member - Posts: 13
Posted: October 12, 2004 at 7:39 AM / IP Logged
 hi need a remote start  diagram for a 1996 ford windstar mini van can any one help me out thanks.
mo12v
Posted: October 12, 2004 at 8:21 AM / IP Logged
This is what I have:
Constant 12 voltsYELLOW (3) & BLK/ORGIGNITION SWITCH HARNESS
Ignition 12 voltsRED / L GREENIGNITION SWITCH HARNESS
StarterWHITE/ PINKIGNITION SWITCH HARNESS *
Dome LightBLACK/ L BLUE (+)14 PIN BLACK CONN. IN DR. KICK PANEL
Trunk Pin SwitchBLACK/ L BLUE (+)SAME CIRCUIT AS ABOVE
Parking LampBROWN (+)14 PIN BLACK CONN. IN DR. KICK PANEL
Power LockPINK / YELLOWDRIVER KICK
Power UnlockPINK/L GREENPANEL
* WHITE/ PINK Starter Wire Without OEM Alarm Only. With OEM Alarm Starter Wire Is RED / L BLUE.
Negative Pulse Door Locks
Accessories
Window UpD\ WHITE/ BLACK P\ WHITE/ YELLOW @ MAIN SWITCH
Window DownR/ YELLOW S/ TAN/L BLUE
Ign Key WarnBLACK/ PINK (-)IGNITION SWITCH HARNESS
Trunk ReleaseN/A
OEM HornYELLOW/L BLUE (-)STEERING COLUMN HARNESS
HeadlightsRED / YELLOW (+)AT HEADLIGHT SWITCH
OEM Alarm ArmN/ASEE NOTES BELOW *
OEM Alarm DisarmD GREEN/ PURPLE (-)DRIVER KICK PANEL
 Reversal Rest At Ground Power Window Circuit
* OEM Alarm Arms 30 Seconds After All Doors Are Closed And Locked Either By Using OEM Keyless Entry Transmitter Or By Locking Doors With Door Lock Switch In Door While Door Is Open And Then Shutting All Doors.
Remote Start
Tach SignalWHITE/ PINKAT POWERTRAIN CONTROL MODULE *
Ignition #2GRAY / YELLOWIGNITION SWITCH HARNESS
Ignition #3BLACK/ L GREENIGNITION SWITCH HARNESS
AccessoryBLACK/ PINKIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightRED / GREEN (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightBLACK/ PINK (+)14 PIN BLACK CONN. IN DR. KICK PANEL
Rear Window DefrostYELLOW/WHITE (-)AT REAR WINDOW DEFROSTER SWITCH
* Powertrain Control Module (PCM) Located On Passenger Rear Of Engine Compartment On Firewall. WHITE/ PINK Wire Located At Pin #48 At PCM. 3.0L Engine WHITE/ PINK Wire Also Found At Ignition Control Module On Passenger Wheelwell.
MO
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
