Defroster Set Up
Jweb
Member - Posts: 49
Posted: October 12, 2004 at 9:19 PM / IP Logged
Got the alarm install completed but now I have a question.  The alarm is a Valet 563T installed in a 02 Astro and the way I understand it, when the vehicle remote starts, the alarm outputs a negative ma signal to start the defroster with the OEM timer.  As I understand it, the defroster is activated every time the vehicle is remotely started.  Why would DEI design a dedicated defroster output to run like this even in summer?  Does DEI have a workaround or a way to program this differently? Defrosters take a lot of current and I'm not too happy with this situation unless I am misunderstanding it all.     Help?    Thanks,  Joe
mo12v
Posted: October 12, 2004 at 9:34 PM / IP Logged
Universal design for a lot of different applications and different climates all over the world, not just U S & Canada, dictate DEI and others having many options
MO
sroth140
Silver - Posts: 513
Posted: October 12, 2004 at 10:29 PM / IP Logged
did you ever thing of buying the pulse/timer relay DEI also sells? you can add it to an extra channel, or install a toggle switch to shut it off for the summer months. the defogger output is for 10min anyway. the current wont hurt anything since the motor is running, but its more wear and tear on the defogger itself.
as far as the factory timer, that depends on the car. most GMs ive done use a (+) trigger to a heavy purple wire on the back of the switch. as long as that has 12volts the defogger stays on. mine doesnt shut off unless i hit ch4 again. and the relay is wired to get 12v from the ign 1 wire, so the defogger wont run if the car isnt running.
MECP certified installer
JWorm
Platinum - Posts: 2,208
Posted: October 13, 2004 at 12:19 AM / IP Logged
I put a switch on the defroster output wire. Before winter I flip it on, after winter I shut it off.
Jweb
Member - Posts: 49
Posted: October 13, 2004 at 10:55 AM / IP Logged
I was hoping I was wrong about how it worked so I guess the toggle switch is the way to go.  Thanks everyone for the information.   JW
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
