Python 881xp on a 98 F150
98blackf150
Posted: October 18, 2004 at 5:19 PM / IP Logged
Alright I am getting ready to hook up my alarm and I have a couple questions I hope someone can answer. (-) ground when armed output. Where the hell do I hook this wire up to. I know you cant just ground it out to the chassis because it says the ground is only when the system is armed. Next is the (-) remote start activation input. No idea. Both of those wire are from the primary harness. If someone could please help me out it would save me a lot of work and stress! Thanks!
mo12v
Posted: October 18, 2004 at 5:25 PM / IP Logged
Usually the Negative Ground when Armed is for a Relay for your Start / Ignition Dis-Able.
The Negative Ground Remote Start Activation is to trigger a Remote Start
MO
98blackf150
Posted: October 18, 2004 at 8:44 PM / IP Logged
I understand that but I just dont know which wires I should hook them up to.
JWorm
Platinum - Posts: 2,208
Posted: October 18, 2004 at 8:53 PM / IP Logged
You don't need either of them. Tape them off.
The orange wire can be used to trigger window rollup modules among other things.
The WHITE/ blue can be connected to a timer module to start the truck at a preset time.
Both wires can be used for other things too....but they aren't necessary.
Teken
Gold - Posts: 1,492
Posted: October 18, 2004 at 8:57 PM / IP Logged
You do realize that he did answer your Q.
Regards
EVIL Teken . . .
98blackf150
Posted: October 18, 2004 at 9:11 PM / IP Logged
So I dont need eithier of them even if I do have the remote start??
Teken
Gold - Posts: 1,492
Posted: October 18, 2004 at 9:27 PM / IP Logged
Depends if you are installing the RS unit. Even then the ground when armed is used in for the alarm portion as it was indicated above.
Starter kill, LED on-off, windows up, sensor(s) on, etc.
Regards
EVIL Teken . . .
98blackf150
Posted: October 18, 2004 at 9:45 PM / IP Logged
Right I am using the remote start unit. So what do I hook the (-) remote start activation wire up to? I am sorry I am just confused! THanks again
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
