remote start 95 neon
neon dohc
Posted: October 22, 2004 at 8:37 PM / IP Logged
Can anyone tell me how to install a remote start on a 95 neon 2.0 dohc. I have a viper 550 and the car is a manual
snguyen
Silver - Posts: 281
Posted: October 22, 2004 at 9:58 PM / IP Logged
DODGE NEON 95-96
WIRE COLORSLOCATION
12 VOLTS CONSTANTPNK/BLK & RED IGN HARNESS
IGNITION 1D BLU   IGN HARNESS
ACCESSORY /HEATER BLOWER 1BLK/ORGIGN HARNESS
STARTERYELIGN HARNESS
PARKING LIGHTSBLK/YEL(+)AT HEADLIGHT SWITCH
DOMELIGHTYEL (-)DRV KICK PANEL
PWR DOOR LOCKPNK/VIOHIGH IN DRV KICK PANEL
PWR DOOR UNLOCKORG/VIOOR BELOW TOP OF DASH (TYPE C)
TACH SENSORD BLU/TANIGN MOD ON TOP OF ENG
BRAKE
TAN(+)AT SWITCH ON BRAKE PEDAL BRACKET
HORN
  BLK/RED(+)STEER COLM
snguyen
Silver - Posts: 281
Posted: October 22, 2004 at 9:59 PM / IP Logged
Dodge
Neon
1995-1996
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS
Ignition  #1:
DARK BLUE
Ignition #2:
BLACK/ ORANGE
IGNITION SWITCH HARNESS (HEAT-A/C)
Ignition  #3:
N/A
Accessory:
BLACK/ WHITE
Brake  Light:
WHITE
(+) AT SWITCH ON BRAKE PEDAL BRACKET
Tach  Signal:
DARK BLUE/TAN AND
BLACK/ GRAY-IGN MOD ON TOP OF ENG *
Parking Lights:
BLACK / YELLOW (+)
HEADLIGHT SW. OR STEERING COLM **
Headlights:
LIGHT GREEN
(+) AT STEERING COLUMN HARNESS
OEM Alarm  Disarm:
N/A
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Each Wire Listed Above Is A 2 Cylinder Signal.
Dodge
Neon
1995-1996
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED AND PINK/BLACK
Starter  Kill:
YELLOW
Ignition  +12 Volts:
DARK BLUE
Dome  Lights/Superv:
YELLOW (-)
DRIVER KICK PANEL OR HEADLIGHT SW. **
OEM Horn:
BLACK/ RED
(+) AT STEERING COLUMN HARN OR RELAY
Power  Lock:
PINK/VIOLET
HIGH IN DRIVER KICK PANEL
Power  Unlock:
ORANGE / VIOLET
OR BELOW TOP OF DASH ***
Trunk  Release:
N/A
NOT OFFERED
Alarm  Input Wire:
YELLOW (-)
Notes:
** Also Found In Gray 16 Pin Connector In Driver Kick Panel. *** See Note #203 - Reverse Polarity Door Lock Diagram.
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
