Pyle PWD250 in 2004 civic coupe
blk_nomad
Posted: October 23, 2004 at 7:03 PM / IP Logged
I just installed this alarm in my civic.  I swear I connected everything correctly.  My problem is that the alarm is allowing me to arm it while the door is open.....is this right?  If I wired it wrong please let me know.
wiring is explained below in Alarm to Car format:
Power to White in ignition harness
Black to ground
Yellow  to BLACK / YELLOW in ignition harness
dome light to two diodes to the green and light GREEN/ red wires in the factory alarm harness
parking lights to RED / black behind fuse box
door triggers to white blue and green blue wires behind kick panel
profuse007
Gold - Posts: 2,015
Posted: October 23, 2004 at 7:20 PM / IP Logged
yeah its right. (i think youre confuse w/ the force to arm passively.)
Houston,TX
blk_nomad
Posted: October 23, 2004 at 8:26 PM / IP Logged
FOrgive me if Im stating what you already said but am I correct in my understanding that the alarm SHOULD be able to be armed while the door is open by me pressing the arm button?  In other words are you saying I have installed the alarm correctly?  Thanks for your answers.
mo12v
Posted: October 23, 2004 at 8:55 PM / IP Logged
There R a lot of Alarms U can ARM while door is open.  Some of them snse the door is closed when the Dome Lights go out
MO
Wednesday, November 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
