tach wire for 1997 Olsmobile Aurora
reuler
Posted: November 06, 2004 at 3:08 PM / IP Logged
Can someone tell me exactly where the tach wire is for a 1997 Olsmobile Aurora??  Instructions say it's while and located at the ignition module.  Can anyone be more specific?
Thanks.
Robin
snguyen
Silver - Posts: 281
Posted: November 06, 2004 at 3:49 PM / IP Logged
Oldsmobile
Aurora
1996-1999
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS **
Ignition  #1:
PINK
Ignition #2:
PURPLE / WHITE
Ignition  #3:
WHITE
Accessory:
ORAN
Brake  Light:
WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE
AT IGNITION CONTROL MODULE *
Parking Lights:
BROWN (+)
AT LAMP CONTROL MODULE
Headlights:
WHITE (-)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
L GREEN (-)
DRIVER'S KICK PANEL
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Ignition Control Module Located On Passenger Front Of Engine (3.8L), Or On Top Rear Of Engine (V-8). ** This Vehicle Is Equipped With GM's VATS Anti-Theft System
Sunday, August 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
