door lock problem 97ford f150
dumb dink
Posted: November 06, 2004 at 8:46 PM / IP Logged
I have a galaxy 5000rs alarm/remote start that im trying to install, everything works but just cant get the door locks to work i have a pink green wire and a pink yellow wire at the door switch along with a black white wire that has a 12 volt constant voltage.  My problem is i have no idea how to wire this up is this a positive system or negative system or is it reverse?  i have so far tryed to hook up the 12 volt constant wire to the red wire and the lock and unlock wires to there corisponding wires.   I tried it positive and neg but it still will not lock or unlock the doors is there something that i am missing here?  Has anyone had expierance with this combonation any help would be welcome Im out of ideas here.
mo12v
Posted: November 06, 2004 at 9:39 PM / IP Logged
U have to hook it up as 5 wire Reversal rest at Ground
Power LockPINK / YELLOWDRIVER KICK *
Power UnlockPINK/L GREENPANEL
* Without OEM Keyless Entry   Reversal Rest At Ground Door Locks
, With OEM Keyless Entry   Negative Pulse Door Locks
MO
dumb dink
Posted: November 07, 2004 at 6:08 AM / IP Logged
Thanks for the reply! PLEASE bare with me. This is my problem I just don't quite understand it. This is what I have on my alarm system (violet)Positive door input,(green)negative door input and on the door plug harness I have (blue) negative unlock output, (red)+ 500mA trigger output for optional plug-in door lock relay module, and (green)negative lock output.
So do I just connect the pink/lt green to negative lock output and pink / YELLOW to negative unlock output?                 Do I need a relay?        Oh and I dont have oem keyless on the truck. If you could just explain to me what wires to hook up to what wires I would greatly appreciate it!  And Thanks for all the help!
Platinum - Posts: 12,488
Posted: November 07, 2004 at 8:45 AM / IP Logged
Does the truck have OEM keyless or not ? Also, you have to get the wires on the driverside of the truck. I've had many experiences where I would grab the wires at the passengerside and blow fuses. When going to the driverside, it works everytime. Post your answer on the keyless issue.
dumb dink
Posted: November 07, 2004 at 6:06 PM / IP Logged
Thanks again and the answer is no I do not have keyless entry. I do have the wires at the drivers side, do I have to cut the pink/lt green and the pink / YELLOW? and if so what wires do I have to connect to them. Thanks again for taking the time to help out guy in need with barely any hair left....lol
profuse007
Gold - Posts: 2,015
Posted: November 07, 2004 at 6:50 PM / IP Logged
yeah cut those wires and wire them like this: two relays
for lock:
85-alarm lock (-)
86-12 volt constant (+)
87-12 volt constant (+)
30-motor side
87a-switch side
for unlock: same thing.
Houston,TX
dumb dink
Posted: November 09, 2004 at 2:37 AM / IP Logged
Many many thanks to all !! I will give it a try this weekend and let you know how it goes. Should do the trick though!
