Trunk pin not setting off alarm
eiknujrac
Member - Posts: 49
Posted: November 09, 2004 at 10:50 PM / IP Logged
I know this question has been answered somewhere on this board before, but I did a search and could not find it again.
I have my trunk connected to the alarm in the hood pin's place. But it will not set off the alarm when initially opened, only when the pin is again pushed in and released. The wire shows 12v when closed and nothing when open (ground?).
Anyone know how to fix?
THanks!
-E
draasch
Gold - Posts: 2,172
Posted: November 09, 2004 at 11:24 PM / IP Logged
lets start off with the car info......................
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Teken
Gold - Posts: 1,492
Posted: November 10, 2004 at 8:54 AM / IP Logged
1. How old is the pin trigger? If it is more than a year old, then simply cleaning the entire pin housing and the surrounding area is a good idea.
You want to ensure that the plunger and the shaft housing is not corroded. Hence why I never use metal style pin switches, and opt for nylon, or magnetic reed switches instead.
2. Is the ground point clean and sound? How do I check?? Take your DMM and measure the resistance with respect to the batteries negative terminal. You are looking for a value close to zero, if not at zero potential. Anything above 1-2 ohms is a bad ground and the area surrounding the mounting point needs to be properly cleaned and prepped.
3. Is the bullet connector securely attached, and free of any contaminates?? If not clean it, and apply dielectric grease to ensure moisture stays out, and promotes current transfer.
4. Is the height of the pin housing correctly adjusted??
You want to have zero travel, meaning it should not allow any amount of gap to be seen, if the hood should be ajar. That is why it is called a instant trigger, not a slow trigger. Check the height and adjust the lock out screw / nut.
Knowledge is power. But only if you apply that knowledge in a positive way, which promotes positive results in others.
EVIL Teken . . .
raydawg357
Silver - Posts: 769
Posted: November 10, 2004 at 10:29 AM / IP Logged
If all else fails, install a mercury switch.
Do it right the first time
eiknujrac
Member - Posts: 49
Posted: November 10, 2004 at 3:56 PM / IP Logged
The car is a 1991 300E, and thanks for the info!
