2000 honda accord
jay's detailing
Member - Posts: 24
Posted: November 11, 2004 at 9:50 AM / IP Logged
I'm in need of a wiring diagram for a 2000 honda accord and i need to if this model needs a transponder if so witch one? one more , I need to know if I can use the factory remote to work the remote starter or can I use the remote tranmitter of the remote start to word the factory alarm?      thanx (angel)
I'm useing a prestigeaps686 as the remote starter system...
snguyen
Silver - Posts: 281
Posted: November 11, 2004 at 9:54 AM / IP Logged
Honda
Accord
1998-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS **
Ignition  #1:
BLACK / YELLOW
Ignition #2:
YELLOW
Ignition  #3:
Accessory:
WHITE/ BLACK
Brake  Light:
WHITE/ BLACK
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
BLUE
AT COIL MODULE
Parking Lights:
RED / BLACK
AT FUSE BLOCK ON DRIVER'S SIDE
Headlights:
OEM Alarm  Disarm:
BLUE
INSIDE OF DRIVER'S DOOR
OEM Alarm  Arm:
BLUE/WHITE
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This vehicle is equipped with a transponder immobilizer system; See Installation Note #144 - Bypassing Transponder Theft Systems.
Honda
Accord
1998-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
Starter  Kill:
BLACK/ WHITE
Ignition  +12 Volts:
BLACK / YELLOW
Dome  Lights/Superv:
BLACK/ WHITE (-)
4 PIN GREEN CONN. IN PASS FUSE BOX
OEM Horn:
BLUE/GREEN (-)
IN STEERING COLUMN HARNESS
Power  Lock:
BLACK/ BLUE (-)
PASSENGER SIDE FUSE BOX**
Power  Unlock:
ORANGE (-)
Trunk  Release:
WHT/RED+
# PIN GRAY CONN. ABOVE DRIVER'S KICK
Alarm  Input Wire:
BLACK/ WHITE (-)
Notes:
** See Note#201 Negative Trigger Door Locks
snguyen
Silver - Posts: 281
ACCORD        1998-2002
WIRE COLORSLOCATION
12 VOLTS CONSTANTWHITEIGNITION SWITCH HARNESS
IGNITION 1BLACK / YELLOWIGNITION SWITCH HARNESS
IGNITION 2WHITE/ BLACKIGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1YELLOWIGNITION SWITCH HARNESS
STARTERBLACK/ WHITE IGNITION SWITCH HARNESS
PARKING LIGHTSRED / BLACK ABOVE FUSE BOX
DOME LIGHTBLACK/ WHITE ( - )PASSENGER SIDE PANEL
POWER DOOR LOCKBLACK/ BLUE ( - )PASSENGER SIDE PANEL NEXT TO DOOR
POWER DOOR UNLOCKORANGE ( - )LT. GREEN PLUG (TYPE B)
TRUNK RELEASEWHITE/ RED ( + )DRIVERS KICK PANEL
TACH SENSORBLUE AT DIST
BRAKEWHITE/ BLACK ( + )SWITCH ABOVE BRAKE PEDAL
HORNGREEN/ BLUE ( - )GREEN 4 PIN PLUG PASSENGER SIDE FUSE BOX
FACTORY DISARMBLUE ( - )IN DRIVERS DOOR AT KEY SWITCH
FACTORY ANTI-THEFTTRANSPONDER791 REQUIRED
snguyen
Silver - Posts: 281
