Passlock II - Security light problem..
sponk
Posted: November 14, 2004 at 9:19 PM / IP Logged
Hi..
I just recently installed a remote start on my 01 Chev Silverado. Everything worked out fine except one little glitch..
I bypassed my passlock using this relay setup.. http://12voltinstallations.8m.com/photo.html
Now everything works fine, no security light when remote started but soon as I put the key in and touch the brake the Security light comes on.. Is there something I am missing here??
Thanks for the help..
draasch
Gold - Posts: 2,172
Posted: November 14, 2004 at 9:23 PM / IP Logged
did you power up all of the ign. wires??
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
sponk
Posted: November 15, 2004 at 12:16 AM / IP Logged
Yes I powered up both ign wires. The light stays off when its being remote started until the key is in and I touch the brake.. Also the light doesn't come on when I start it with the key...
draasch
Gold - Posts: 2,172
Posted: November 15, 2004 at 5:52 AM / IP Logged
number 1 Ignition 12 volts PINK IGNITION SWITCH HARNESS
Ignition #2 WHITE IGNITION SWITCH HARNESS #216
Ignition #3 ORANGE IGNITION SWITCH HARNESS (HEAT/AC)
Accessory BROWN IGNITION SWITCH HARNESS
see if this helps.....
Good Luck
David
Ace Security
813-376-9778
Tampa
Platinum - Posts: 12,488
Posted: November 15, 2004 at 6:35 AM / IP Logged
Check to make sure that your ground for the RS is reading absolute 0. Also, ensure that you are getting an absolute 0 reading off your ground when running wire as well. I have seen many problems where the (-) status or ground when running wire doesn't ground properly throughout the RS sequence and causes this light to come on. If you have to, use a relay to boost the negative signal of the status wire for a better ground.
Tuesday, April 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
