1997 grand am gt help
mikee2122002
Member - Posts: 21
Posted: November 15, 2004 at 8:25 AM / IP Logged
I want to say i am dumb at this but i have a nitro 2way lcd alarm plus starter which is a all in one but i need help to know which ignation wire i need to hook up to get the car started. So if u can plz help me and tell me where the wire are i would really appericate it
mo12v
Posted: November 15, 2004 at 9:17 AM / IP Logged
Vehicle                                 COLOR                                     LOCATION
Constant 12 voltsRED & REDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightL GRN/BLK & L BLUE (-)AT CONVENIENCE CENTER MODULE *
Trunk Pin SwitchORANGE / BLACK (-)AT LIGHT IN TRUNK
Parking LampBROWN (+)AT LIGHT SWITCH OR DRIVER KICK PANEL
Power LockL BLUEEITHER KICK
Power UnlockWHITEPANEL
* Convenience Center Module Located Behind Driver Dash To Left Of Steering Column. L GREEN/ BLACK (-) Covers Driver Door, L BLUE (-) Covers All Other Doors. Diode Isolation Needed, Cathode (Band) Side Of Diode Faces OEM Wires.
Positive Pulse Door Locks
Accessories
Window UpD\ D BLUE P\ L BLUE D\ D GREEN P\ L GREEN @ MAIN SWITCH
Window DownF/ BROWN F/ TAN R/ PURPLE R/ PURPLE
Ign Key WarnL GREEN (-)STEERING COLUMN HARNESS
Trunk ReleaseBLACK (+)AT OEM KEYLESS MODULE IN TRUNK *
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsYELLOW (+)AT HEADLIGHT SWITCH
OEM Alarm ArmN/ANO OEM ALARM PRESENT
OEM Alarm DisarmN/AIN SCHEMATICS
Reversal Rest At Ground Power Window Circuit Diagram. * BLACK (+) Wire For Trunk Release Is With OEM Keyless Only. Without OEM Keyless Trunk Release Is Cable Operated.
Positive Pulse Trunk Release
Remote Start
Tach SignalWHITEAT POWERTRAIN CONTROL MODULE *
Ignition #2ORANGEIGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3WHITEIGNITION SWITCH HARNESS **
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyORANGE / BLACK (-)AT CONVENIENCE CENTER MODULE ***
Brake LightL BLUE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightL GREEN (+)PASSENGER KICK PANEL
Rear Window DefrostL BLUE (+)AT REAR WINDOW DEFOGGER SWITCH ****
* 3.1L Engine Tach Wire Is WHITE Or PURPLE / WHITE At Powertrain Control Module. Powertrain Control Module On Both Engines Located Behind Pass. Dash ** WHITE Wire Powers Instrument Cluster And Transmission Control Module. *** Convenience Center Module Located Behind Dr, Dash To Left Of Steer. Col. **** L BLUE (+) Wire Also Located At Convenience Center Module.  G.M. Passlock
MO
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
