2003 cavalier alarm
leezard37
Posted: November 15, 2004 at 11:40 AM / IP Logged
hi, can someone tell me where the ignition switch is located on a 2003 cavalier. thanks2003 cavalier alarm -- posted image.
sparkie
Platinum - Posts: 2,061
Posted: November 15, 2004 at 4:29 PM / IP Logged
The ignition switch is what you put your key into to start the car. You can access the wiring for it by removing the 3 screws on the underside of the steering column plastic shroud. You may also have to unscrew the tilt steering lever. It has lock tite on it so you may need pliers to loosen it.
sparky
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
