96 Chevy 4x4 Ignition Failure
mano
Member - Posts: 7
Posted: November 16, 2004 at 6:48 PM / IP Logged
My truck  was running fine, then the next day I tried to start it & when you turn the key it want do anything. The dash lights & all the power works it just want start, engine will not even roll over.I am thinking it has someting to do with the alarm. It has a factory GM alarm installed in it.Any tips would be great.
Thanks, Mark
draasch
Gold - Posts: 2,172
Posted: November 16, 2004 at 9:43 PM / IP Logged
is there any aftermarket alarm/remote start unit installed?????
have you tried or checked the ign. switch that is located on top of the colunm??? its towards the bottom of the colunm...it will have a rod attached to it....sometimes that will cause a problem.......
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
mano
Member - Posts: 7
Posted: November 16, 2004 at 10:20 PM / IP Logged
It has a Gm alarm installed but it doesnt look factory installed , I just checked it out, the ignition wire ( KEY ) going into the alarm box is getting power when I turn the ignition, & every thing else seems to be working fine on the alarm box, but still no ignition. I guess maybe the ignition switch is broken. The only other thing is another wire labeled ( MOTOR ) has no power to it going into the box.It plugs into the box along with the wire for the ignition. Could this be the problem? It seems like it should have power to it , at least when you turn the key on.
Thanks, Mark
draasch
Gold - Posts: 2,172
Posted: November 17, 2004 at 6:42 AM / IP Logged
are you able to unplug the unit and see if that makes a difference???
see if you can find a model number on the unit and post it...
Good Luck
David
Ace Security
813-376-9778
Tampa
mano
Member - Posts: 7
Posted: November 17, 2004 at 11:39 AM / IP Logged
Yeah, I have already unpluged the unit, It made no difference.
Thanks, Mark
mano
Member - Posts: 7
Posted: November 17, 2004 at 7:36 PM / IP Logged
I got it !!!!!!!!!!!!!!  Thanks David . I traced everything possible, Straight down to the starter. I had someone turn the ignition key whiles I checked the power wire going to the starter & thats what it was.
Thanks, Mark
