98 chevy pickup remote start
92maxse
Posted: November 17, 2004 at 12:44 AM / IP Logged
putting in a autopage rs-850 in my friedns 98 chevy pickup have the remote starter installed have it progrmed for the timer start but when i remote start it it cranks and then dosnt stay running i hve tryed seting the timer longer but then it just cranks longer then dies again also where exactly are the wires for the keyless entry and how do i wire that up is it the reverse polarity locks
draasch
Gold - Posts: 2,172
Posted: November 17, 2004 at 6:48 AM / IP Logged
Power Lock L BLUE DRIVER KICK #203
Power Unlock WHITE PANEL ** #202
** Without OEM Keyless Entry See Note #203. With OEM Keyless Entry See Note #202. #203 - See Reversal Rest At Ground Door Lock Diagram. #202 - See Positive Pulse Door Lock Diagram.
put the key in the ign. and try to start it...see if it stays running...if it does, then you need to use a passlock II bypass kit......
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
