2004 Nissan Murano Door Lock issue
majestic*
Member - Posts: 9
Posted: November 18, 2004 at 10:27 AM / IP Logged
hey all,
Just trying to figure out how I can run wire through the molex plug in the door jam to get to the wires in the driver's door switch (which I've found and tested) in the door?
Is there another place where I can get lock/unlock from without going into the door? I've tried doing a continuity test from the wires in the door switch to the wires coming into the driver's kickpanel area and none of the wires seem to be working for me (meaning I can't tap into the wires before the door?!)
Any ideas.
Thanks in advance,
Nick
Platinum - Posts: 12,488
Posted: November 18, 2004 at 12:29 PM / IP Logged
Yes ther eis another spot for this on all Nissan's. I'll have to get back to you when I get back to the shop but if someone else has an idea please post, otherwise I'll post this information later this afternoon for you.
riceman
Copper - Posts: 109
Posted: November 18, 2004 at 1:29 PM / IP Logged
2004 Nissan Murano (should also apply to 2003):
BCM is high up to the right of the steering column. Route your remote starter's lock wires right along with the ignition wires.
Lock/arm is 13, disarm/domelight turnon/double-pulse unlock is 14. Does not control windows
There are empty pins that can control the lock/unlock simply strip wires n put into the pins in the bcm.I havnt verified this information but if you look it up all the nissian and infinity are covered by Chris
*This information is from Chris Lungo a member of this forum "sorry if i butchered  your last name"
majestic*
Member - Posts: 9
Posted: November 19, 2004 at 10:45 AM / IP Logged
Hey Jeff...
Do you have any info on this yet?
Thanks,
Nick
riceman
Copper - Posts: 109
Posted: November 19, 2004 at 1:44 PM / IP Logged
Here is the link with pictures , hopefully that helps.
http://www.carsound.com/UBB/ultimatebb.php?ubb=get_topic;f=3;t=002070;p=1#000019
