PK2 recover
daniel2002p
Silver - Posts: 524
Posted: November 24, 2004 at 10:09 PM / IP Logged
Does anybody know when you lock a late model GM car with the Passlock II how do you recover it correctly.  I have read many posts but all of them seem to have a different way of doing it.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Platinum - Posts: 12,488
Posted: November 24, 2004 at 10:14 PM / IP Logged
Leave the key in the ignition and have it turned to the ON position for about 15-20 minutes ( up to 30 for some vehicles ) and the Passlock light will flash the entire time. Once it resets, the light will go out and you can start the car again with the key. Is this what you were looking for ????
cgalvin29
Member - Posts: 35
Posted: November 24, 2004 at 10:24 PM / IP Logged
Velocity beat me to it thats the only way ive seen it done i was once told you can reset the ecm but thats not true, this is the easiest way.
daniel2002p
Silver - Posts: 524
Posted: November 25, 2004 at 9:51 AM / IP Logged
yes it is, also can you confirm this.  I have heard the the drivers door HAS to be locked and closed or it would not work.  Can you tell me if this is true or do these two factors have nothing to do with the reseting portion.
    1.8L VVT-i I-4
Posted: November 25, 2004 at 11:27 AM / IP Logged
That is not true. I just did an Intrigue the other day where I had to reset the Passlock II and I had the door open for the longest time and then I closed the door and still had the door unlocked.
Posted: November 25, 2004 at 11:29 AM / IP Logged
The other way to reset the Passlock II is to remove the ground from the battery, but then you have to wait up to 1 hour for this and you also need the Theftloc code for the radio to be reset if it's been set once before.
daniel2002p
Silver - Posts: 524
Posted: November 25, 2004 at 2:31 PM / IP Logged
Cool, thanks Jeff, just wanted to clarify that.  Preciate the help!!!!!
    1.8L VVT-i I-4
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
