Parking light circuit
davidosand
Member - Posts: 36
Posted: November 25, 2004 at 7:50 PM / IP Logged
I have 2004 full size GMC  van. I need to find the parking light circuit for light flash output. someone told me it was a brown wire at fuse box under the seat. but there are several small brown wires. And the light switch has 2 BROWN / white wiree, one of which shows +12v when the switch is off and 0v when it is on. Does anyone have any ideas or can you tell me where I could get a schematic?
davidosand
Member - Posts: 36
Posted: November 25, 2004 at 7:53 PM / IP Logged
By the way. that is a GMC Savannah. Thanks.
Hymer
Silver - Posts: 695
Posted: November 25, 2004 at 10:40 PM / IP Logged
One of the wires at the switch is it. you need to convert your + output for your rem start to a ground output (either by programing or use a relay) that should work.
davidosand
Member - Posts: 36
Posted: November 26, 2004 at 8:51 AM / IP Logged
Thank you so much. I suspected that it was neg. switching instead of positive . I just wanted to be sure. That's what this site is all about....helping out your fellow man.
Thanks again for responding;
David Sanderson
Moderator - Posts: 12,488
Posted: November 26, 2004 at 11:42 AM / IP Logged
Just use the (-) parking light wire instead at the BCM ( BROWN / WHITE )
Tuesday, December 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
