Remote start clutch bypass and safety
soulreaver
Posted: October 12, 2002 at 4:53 PM / IP Logged
Trying to bypass the clutch on a 1996 Ford Explorer Sport. On most cars or trucks their are only two wires for the satety neutral switch, but on this Ford Explorer Sport their are six wires. I have no clue which one's to use to bypass the switch. So if anyones has an Idea hit me back ok. The switch wire color codes is :
Lt. Blue / Yellow , Gray / Red , Lt.Brown / Blue , Green , Pink , White / Pink
Look out for the Soulreaver!
brianh
Silver - Posts: 518
Posted: October 12, 2002 at 6:36 PM / IP Logged
The information I have says that the ford explorer has a non grounding type neutral safety switch.  If that is true just run your safety switch wire straight to ground.  If im wrong someone please correct me.  Brianh
