2001 accent alarm help
shanesullivan32
Posted: November 27, 2004 at 3:37 PM / IP Logged
i need the wiring diagram for this car to set up an alarm
draasch
Gold - Posts: 2,172
Posted: November 27, 2004 at 3:43 PM / IP Logged
Make:   Hyundai
Model: Accent
Year:    2001
This Database Was Last Updated On:    9/16/2004
Index #: 9999
Alarm
Constant 12 volts BLACK/ BLUE OR RED IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ WHITE OR GREEN IGNITION SWITCH HARNESS
Starter BLACK / YELLOW OR WHITE IGNITION SWITCH HARNESS
Dome Light GREEN (-) 20 GAGE WIRE IN DRIVER KICK PANEL
Trunk Pin Switch GREEN/ ORANGE(-) 18 GAGE IN DR KICK OR LIGHT IN TRUNK
Parking Lamp GREEN/ BLACK (+) DRIVER KICK PANEL
Power Lock ADD ACTUATOR ADD ACTUATOR TO DRIVER DOOR #204
Power Unlock ADD ACTUATOR ADD ACTUATOR TO DRIVER DOOR #204
#204- See Adding Actuator Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
rudbwoy69camaro
Silver - Posts: 350
Posted: November 27, 2004 at 3:47 PM / IP Logged
2001 Hyundai Accent
ItemWire ColorPolarityWire Location
12Vred+ignition harness
STARTERwhite+ignition harness
IGNITIONgreen+ignition harness
ACCESSORYyellow+ignition harness
SECOND ACCESSORYnone
TACHOMETERgray *2ECM under driver dash, pin 8
POWER LOCKadd actuator *4in driver door
POWER UNLOCKsame
PARKING LIGHTS +grn/org(L),grn/blk(Rdriver kick panel
PARKING LIGHTS -greenheadlight switch
DOOR TRIGGERgreen-driver kick panel or cluster
HEADLIGHTSyellow-headlight switch
WIPERSgreen (L), brown (H)-steering column
LF WINDOW UP/DNblue - greenAdriver window switch
RF WINDOW UP/DNgray - orangeAdriver kick panel
LR WINDOW UP/DNblack - greenAdriver kick panel
RR WINDOW UP/DNwhite - blueAdriver kick panel
TRUNK/HATCH PINGREEN/ orange-driver kick panel or cluster
HOOD PINyellow/black-pin switch
TRUNK/HATCH RELEASEnone
FACTORY ALARM ARMnone
FACTORY ALARM DISARMnone
HORN TRIGGERblue/orange-steering column
BRAKE WIREpink/black+brake pedal switch
LOCK MOTORnone
UNLOCK MOTORnone
DISARM DEFEATnone
DISARM NO UNLOCKnone
DOME SUPERVISIONuse door trigger
SPEED SENSEWHITE/ blackdata link connector *3
SUN ROOF OPEN/CLOSEnone
SUN ROOF LIMITnone
LF SPEAKERred - blueradio
RF SPEAKERwhite - brownradio
LR SPEAKERgreen - orangeradio
RR SPEAKERorange - blueradio
RADIO 12VORANGE / black+radio
RADIO GROUNDblack-radio
RADIO SWITCHblue/black+radio
RADIO ILLUMINATEGREEN/ orange+radio
POWER ANTENNApink+radio
Notes:*1 This wire is not required for remote start. *2 Can also use blue or brown at the ignition coils. *3 The data link connector is under the driver side dash. *4 Vehicle with keyless entry use BLACK/ orange for lock and yellow for unlock. They are negative trigger and found at the ETACS module to the left of the steering column.
