2003 Dodge Ram 2500 Diesel al/rm st
J.T. corbitt
Posted: November 29, 2004 at 9:48 AM / IP Logged
I am trying to install a Audiovox Prestige 786 alarm and remote start in this vehicle.  I have found several wiring color codes bu most conflict on some of the wires on the truck.
The Glow Plug wire location.  Is it on the ECM on the lower driver side of the engine or on the PCM on the passegner firewall?
The Tach wire location.  Is it on the PCM and what location?
The wires in the driver kick panel for the door locks don't even resemle the colors that I found at Direct Wire.
Last but not least, I can't find a door trigger wire for the driver's door.
Any help or advise would be great
monster57
Posted: November 29, 2004 at 10:26 AM / IP Logged
it is on the lower driver side of the motor from what i recall there are 2 sets of wires it is the front one. looks like a steel box on the side of the motor can reach it from under the car better.  The door trigger is lock and unlock on one wire u have to use resistors try whatever directed says get a couple extra try it cant damage it.
monster57
Posted: November 29, 2004 at 10:29 AM / IP Logged
oh btw u dont need a relay on the door trigger
J.T. corbitt
Posted: November 30, 2004 at 1:37 AM / IP Logged
Quick put the fire out!!!
I wired everything in.  Although several opinions are out there about the tach wire, I wired it to the PCM, ORANGE / black, after testing it with a DMM and the engine running.  This was the major wire that I still needed to hook up today.  Now I have the following troubles at the dash.
ABS and Brake lights-On
Air Bag Light- On at start then off for about 2 seconds then on again
Speedometer not working. Cruise and Door auto locks not engaging (may be from speedometer not working)
No A/C the at the button or heated mirrors.  The level control is also out.  I know that the heated mirrors worked this morning prior to connecting the tach wire. WHAT HAVE I DONE?
Platinum - Posts: 12,488
Posted: November 30, 2004 at 1:59 AM / IP Logged
There are several IGN & ACC wires that all need to be powered up during remote start that you probably did not hook up yet. Make sure that yo have these hooked up in the ignition switch harness:
12V|pnk/blk & RED / wht   |+  |ignition harness
STARTER|small yellow              |+  |ignition harness
IGNITION|blue     (16 awg)   |+  |ignition harness
SECOND IGNITION|small RED / white    |+  |ignition harness
ACCESSORY|green       |+  |ignition harness
SECOND ACCESSORY|small orange  |+  |ignition harness
As far as the speedometer, remove that connection from the PCM and find a YELLOW/WHITE wire on the driver's side of the cylinder head in a 4 wire gray connector.
jaurora
Silver - Posts: 429
Posted: November 30, 2004 at 9:16 AM / IP Logged
Also on that alarm the GREEN/ YELLOW wire (GLOW PLUG) is not necessary. The unit needsto be programed from gas to diesel and change the setting in the program mode for either a 10,15,20 second warmup before the truck starts. All this can be found in the remote start programing portion of the manual.
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS
Ignition  #1:
BLUE (16 AWG)
Ignition #2:
RED
Ignition  #3:
GREEN & ORANGE (2 WIRES)
Accessory:
BLACK/ WHITE & BLUE (2 WIRES)
Brake  Light:
WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
TAN/RED
AT IGNITION COIL
Parking Lights:
PURPLE / YELLOW
HEADLIGHT SWITCH*
Headlights:
PURPLE / YELLOW
HEADLIGHT SWITCH *
Diesel  Glow Plug:
ORANGE / Black
Powertrain Control Module***
Clutch  Bypass Wire:
Notes:
 * This Is A Single Wire System. Parking Lights Need To See A Ground (-) Through A 330 Ohm Resistor. Headlights Need To See A Ground (-) Through A 700 Ohm Resistor. ** Diesel Vehicles - ORANGE / Black Wait to Start; Tach Wire Is Gray/Black. Both Wires Are Located In A Black Connector Center Top Of Fire Wall. There Are Two Black Connectors, The Correct One Does Not Have A White Insert. *** Tach can also be located at pin 74 behind instrument cluster
MECP certified (If it really means anything)
Jeremy
partyguy
Member - Posts: 30
Posted: November 30, 2004 at 5:23 PM / IP Logged
what about the disarm resistance got one?
Posted: November 30, 2004 at 6:56 PM / IP Logged
Arm/lock is negative trigger thru a 2K ohm resistor. Disarm/unlock is negative trigger thru a 480 ohm resistor. Single pulse will do disarm without unlocking the doors. Unlock requires a double pulse. MUST use relays.
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
