PKU-MIT faulty or need Dealer to program
srusin1
Copper - Posts: 86
Posted: November 29, 2004 at 5:59 PM / IP Logged
Has anyone had problems with this bypass. It looks kind of skimpy. I have tried to program it over and over again with no luck. Its for a 2002 Mitsubishi Galant.I called them and they said i need to take it to a dealer. The dealer said they dont know how to program it.
draasch
Gold - Posts: 2,172
Posted: November 29, 2004 at 9:28 PM / IP Logged
who did you call?????
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
srusin1
Copper - Posts: 86
Posted: November 29, 2004 at 10:10 PM / IP Logged
I called bypasskit.com technical support.
draasch
Gold - Posts: 2,172
Posted: November 29, 2004 at 10:24 PM / IP Logged
send me your info via e-mail......the part number and how you wired it up...also include the car info....i will call them and see what i can find out....im a dealer with them.....
Good Luck
David
Ace Security
813-376-9778
Tampa
JWorm
Platinum - Posts: 2,208
I've only used that bypass once. Last winter in an Outlander I think.   Worked fine. The instructions weren't quite right. Read in the vehicle's owner manual how to program a new key and follow it instead of the bypasskit instructions.    It think you had to do one step for almost 20 seconds when the instructions said 10.
srusin1
Copper - Posts: 86
Posted: November 30, 2004 at 9:55 AM / IP Logged
Did you get the security light to go on for 3 seconds when you finished programming?
Monday, April 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
