2003 buick VATS
mistahiggs
Member - Posts: 29
Posted: December 02, 2004 at 6:39 PM / IP Logged
I installed a remote start on an 03 buick century by using the resistor pack and a relay. The car starts fine, and the remote start works everytime. Once in a while after being remote started and shut down, the key will not start the car, no crank, nothing. But the car can be remote started no problem. Any ideas of what's going on here and how to fix it?
thanks
higgs
zargon
Copper - Posts: 186
Posted: December 02, 2004 at 10:18 PM / IP Logged
what kind of remote start is it? did you put a starter kill anti grind relay in, if you did sometime you will lock the car with the remote and enter some other way like with the key or reaching through the window, the unit will be in an anti theft mode and all you have to do is unlock with the remote that came with the remote start and it should work, anyway that an idea.
zargon ruler of estranorth
mistahiggs
Member - Posts: 29
Posted: December 02, 2004 at 10:25 PM / IP Logged
it is a Viper 160XV remote start with keyless entry, but the keyless entry is not hooked up
Dreadlock
Copper - Posts: 55
Posted: December 03, 2004 at 4:31 PM / IP Logged
using a bitwriter turn off securitry features, if that is not it, check connection on relay,
Sar
Member - Posts: 21
Posted: December 03, 2004 at 6:19 PM / IP Logged
your relay might be to far away and the resistance of the extra wire has changed your value from the cylinder.
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
