installing door actuators and alarm
enwycee
Member - Posts: 6
Posted: December 06, 2004 at 8:06 PM / IP Logged
I recently bought an Autoloc CA4000 4 door actuator kit w/ alarm. The alarm is a Stellar ST8000. My car is a 95' Honda Civic DX Sedan. I have an idea on how to install the actuators but I am not sure about the alarm. To install the actuator control module to the alarm module you have to connect a brown wire to a blue/white one and a white wire to a GREEN / WHITE one, on the the alarm module. You also need to connect a black ground wire and red 12V constant. I am not sure where I can hook these up to under my dash. There is also a whole bunch of wires that are coming from the alarm module that I am not sure of. If anyone can help me out, It would be greatly appreciated.
Teamrf
Gold - Posts: 1,031
Posted: December 06, 2004 at 8:23 PM / IP Logged
What is your exact question? First you need to prep the alarm. Mount the door acuators in the door, and run wires into the car. Connect the two relays for the doors to the alarm lock wires...All of your power is going to come from under the dash
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
