Astro Locks in 04 E350 Van
Hymer
Silver - Posts: 695
Posted: December 07, 2004 at 4:59 PM / IP Logged
Our shop is doing a AstroStart in a 04 E350 Van. My question is -
1. what are the door locks in this thing. I have several different wire colors/locations from different sources. The RS was pre wired for 5 wire rev. , BUT I find on the lock / unlock wires (pink/grn, pink/yel I think) at the VSM are each triggered by a ground, and 12v is not found at the switch. (passenger side)
2. (keep in mind I didn't start this install, I got thrown into it, because of a employee termination) The relays on the RS are on board, pin 87 is wired to fused 12v on both lock and unlock, this gives me 12v on pin 30 when the lock or unlock in pressed on the remote. In my mind I run those wires to ground thus giving me a ground pulse for my desired function. Is that correct??
Sorry if this sounds confuseing, but like I said I got thrown into this and am just looking for a quick answer.
draasch
Gold - Posts: 2,172
Posted: December 07, 2004 at 9:10 PM / IP Logged
see if this helps:
Make:   Ford
Model: Econoline
Year:    2003
This Database Was Last Updated On:    9/16/2004
Index #: 4951
Alarm
Constant 12 volts YELLOW (2) IGNITION SWITCH HARNESS
Ignition 12 volts RED / LT.GREEN IGNITION SWITCH HARNESS
Starter WHITE/ PINK IGNITION SWITCH HARNESS
Dome Light BLACK/ BLUE (-) DRIVERS KICK PANEL
Trunk Pin Switch
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock RED DRIVERS KICK PANEL #203
Power Unlock BROWN DRIVERS KICK PANEL
#203 See Reversal Rest At Ground Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Hymer
Silver - Posts: 695
Posted: December 07, 2004 at 11:21 PM / IP Logged
Thanks David however I don't have those wires for the lock/unlock (red & brown) in this van. I think it might have factory keyless in it. I'll let you guys know what happens tomorow. I might take over the install and do it from ground up. It threw me for a loop today just for the fact that it was late in the day and it is definitly different from our othe vans we deal with...
Hymer
Monday, January 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
