fixed: Valet 554R help please?
fooser
Member - Posts: 15
Posted: December 16, 2004 at 8:39 PM / IP Logged
Can somebody please take a look at this and let me know if I’ve got it wired right, and help me with the ones I’m not sure about.
2003 GMC Sierra, 2 door, automatic, and no power door locks
DEI Valet 554R, GMDL-BP, and a power door lock kit
Primary harness H1
RED / white – (-)200mA ch2 validity output = not sure?
Red – (+)12 volt constant
Brown – Siren (+) output
Black – Chassis ground
Violet – (+) door trigger = all door trigger (+)gray/ black wire in drivers “A” pillar
Blue – optional sensor = not used
Green – (-) door trigger = since im using the +door trigger, will I need this?
BLACK/ White – (-)200 mA dome light supervision = not sure?
WHITE/ Blue – (-) remote start activation= not sure?
White – Selectable light flash= vehicle light switch (-)violet wire
Orange – (-)500 mA ground when armed output= not used, since the 554R has the starter kill built in, I think this is right?
Secondary Harness H2
Gray/Black – wait to start input = not used
Light GREEN/ Black – factory disarm/special accessory output= not used?
Violet/Black – Programmable channel 4 output= maybe a future upgrade like a electric tail gate lock?
Relay Satellite Key Switch Interface
All wires go to the relay block, so coming out of relay block
Pink – 1st and 2nd ignition relay turn on = not sure truck wiring diagram shows #1 ignition (pink) #2 ignition (white), and do I cut them or just tap into them?
Purple – (-)200 mA Starter relay turn on = does this go to the starter #1 wire (yellow),do I cut it or just tap into it?
Orange – accessory output – not sure, wiring diagram for truck has acc1 (orange wire) and acc2 (brown wire)
Remote Start Harness H3
Blue – (-)200 mA status/factory security rearm output = not used?
Blue/Black – (-)200 mA optional third ignition output = not used?
Gray – hood pin switch = self explanatory
Brown – (+) Brake switch shutdown = White wire at brake pedal switch
Violet/White – Tach input wire = instrument cluster white wire
BLACK/ White – (-) neutral safety switch = Where is the wire I tap into located on the truck and what color is it?
Door Lock Harness H4
Green – (-) lock (+) unlock output = I’ll have to use a DMM and test the wires coming out of the actuators
Blue – (-) unlock (+) Lock output = I’ll have to use a DMM and test the wires coming out of the actuators
That’s all the Harness’s, now I’m wondering how to wire the GMDL-BP into this? Any help would be appreciated.
p.s. Sorry about the previous post, like a dumba** I used word to format it, and couldnt figure out how to edit the post after I posted it.
auex
Platinum - Posts: 5,041
Posted: December 16, 2004 at 10:45 PM / IP Logged
PRIMARY HARNESS
RED / white – Used for acc outputs such as trunk pop.
Red – goes to constant +12V in ign harness
Brown – goes to the red wire off of the siren.
Black – ground
Blue – would go to hood/trunk pin or other sensor, don't worry about the hood as there is another input.
Green – No connection if you are using the + door trigger
BLACK/ White – If not sure then don't use this wire as you can cause damage to BCM if hooked up incorrectly.
WHITE/ Blue – This wire would go to a momentary switch if you wanted to use a button to activate the remote start without using the remote.
Orange – If starter kill is built in then don't use. Can go to window module as well.
Gray/Black – Used for diesel engines.
Light GREEN/ Black – Not needed.
Violet/Black – Used for other acc outputs, can be programmed to validity, latched, latched with ign reset, or 30 sec timed.
Pink AND pink/white–   Just tap into the cars wire for this. Pink goes to one of the ign wires and pink/white goes to the other.
Purple – This should actually be a + output and would go to the cars starter wire.
Orange – Hook this to one of the acc wires. You will need a relay to activate the 2 acc wire using the Blue/Black – (-)200 mA optional third ignition output.
Blue – Not used
Blue/Black – Used to activate the second acc wire listed above
BLACK/ White – If the truck is auto then ground this wire, if the truck is manual then you are on your own.
GMDL-BP is gonna be another post.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
fooser
Member - Posts: 15
Posted: December 17, 2004 at 11:35 AM / IP Logged
Auex,
Thanks for the help, but I do have a few questions I was wondering if you, or anybody else could answer
1.  The dome light has an auto-off function, so would I want to avoid using the all door trigger?  My guess is that this wire goes to the dome light, and if it auto's off wouldn’t that pose a problem?
"However, some vehicles have a dome lamp delay and/or an auto off feature. On many of these, you will want to locate the trigger lead(s) that will show either ground or (+) 12VDC when each door is opened, that is not affected by the dome lamp being on or off."
2.  Also I believe that each door has a separate trigger, so would I use diodes to isolate the triggers as quoted below?
"On the vehicles that have two separate (-) door triggers that are isolated from each other, most commonly found on newer GM vehicles, you will need to use two 1 amp blocking diodes for all doors to trigger the alarm. One trigger is for the driver's door and the second is for the rest of the doors. If you were just to connect to one of these and not both, one or more doors of the vehicle would not be protected by the alarm. If you were to tie each of these together without the blocking diodes, some features of the vehicle will no longer function properly."
     Quoted from https://www.the12volt.com/carsecurity/page5.asp
Again thanks for the help, I’m sure that I am probably reading a little much into this install, but it is my first one and I like to be thorough and do my research. That way I can do it right the first time and not screw anything up.
