Viper 791XV 2000 Prelude Installation
Lude2Envy
Posted: December 19, 2004 at 7:09 PM / IP Logged
Has anyone installed the Viper 791XV in a 5th generation Honda Prelude? If so I'm looking for wiring diagrams for the cars electrical system and any other useful information for this installation. Thanks.
lude2envy
swamprat323
Gold - Posts: 1,335
Posted: December 19, 2004 at 8:18 PM / IP Logged
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white               |+ |ignition harness            |
|          STARTER|BLACK/ white        |+ |ignition harness            |
|        IGNITION|BLACK / YELLOW        |+ |ignition harness            |
|        ACCESSORY|yellow              |+ |ignition harness            |
|       POWER LOCK|BLACK/ white        |- |*1                          |
|     POWER UNLOCK|blue/orange        |- |*1                          |
|       LOCK MOTOR|WHITE/ red           |   |bottom of fuse box          |
|     UNLOCK MOTOR|lt.GREEN/ red        |   |bottom of fuse box          |
|    DISARM DEFEAT|red                 |   |bottom of fuse box          |
| PARKING LIGHTS +|RED / black           |   |*2                          |
|       HEADLIGHTS|blue/red            |- |steering column             |
|     DOOR TRIGGER|WHITE/ black        |- |bottom of fuse box          |
| DOME SUPERVISION|comes on with unlock|   |                            |
| TRUNK/HATCH PIN|orange              |- |*2                          |
|FCTRY ALRM DISARM|                    |   |                            |
| DISARM NO UNLOCK|blue               |- |in drivers door             |
|       TACHOMETER|blue               |   |cluster or test connector *3|
|       BRAKE WIRE|WHITE/ black        |+ |at brake switch             |
|     HORN TRIGGER|blu/rd or lt grn/blu|- |steering column             |
|           WIPERS|blue, blue / YELLOW   |- |at switch                   |
| LF WINDOW UP/DN|RED / blu - RED / yel   |A |drivers door switch        |
| RF WINDOW UP/DN|blu/yel - blue      |A |*4                          |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. *1 located in the passengers kick at the multiplex control unit in a blue 14 pin connector. *2 located in a white plug just behind the cruise control switch. *3 test connector is located to the front of the right strut tower.   *4 located in the passengers kick at the multiplex control unit in a 20 pin plug
As with most hondas easy install.
