Passlock 1 problems
drifter-CT
Member - Posts: 7
Posted: January 01, 2005 at 8:37 PM / IP Logged
ok heres the situation the car is a 95 or 96 sunfire. A DEI 555L was used, the car starts with the key and also remote starts but the theft light stays on solid all the time. I thought the 555L might have a problem so I removed it  and the light still stays on and the car can still remote start just fine as if it did not have passlock. I checked for a resistance and can't get anything. The light is just on solid all the time. passlock lose its resistance???
Trav3D1
Copper - Posts: 146
Posted: January 01, 2005 at 9:41 PM / IP Logged
This happens sometimes with GM's.  Just a tip that I used in the past........Remove the 12v side of the battery for approx. 15 - 30 mins.  Reconnect and retest all functions of the R/S.  This typically resets the factory alarm.
Good Luck
Trav
Papol
Member - Posts: 11
Posted: January 01, 2005 at 9:50 PM / IP Logged
did you hook up the factory alarm disarm wire on your aftermarket alarm to the factory?
drifter-CT
Member - Posts: 7
Posted: January 02, 2005 at 8:42 AM / IP Logged
no, I didn't hook up the factory disarm wire. The car doesn't even have power locks would it have an alarm? Or is alarm just another word for passlock?
The Customer's Car is coming back on friday so I'll try the disconnecting of the battery.  That should get passlock working the way it should again?
Craig3708
Copper - Posts: 155
Posted: January 02, 2005 at 8:17 PM / IP Logged
If the Passlock (DATA) wire was cut in the begining with the car running and never reconnected correctly this would cause the light to stay on and all functions to work normally. Try removing the bypass module and rejoining the passlock wire and then restart the car with the key..........
       Craig...
drifter-CT
Member - Posts: 7
Posted: January 03, 2005 at 9:11 AM / IP Logged
yeah I removed the bypass and restarted with the key, the light still stays on. :(
Will I Have to take it to a dealer?
Craig3708
Copper - Posts: 155
Posted: January 03, 2005 at 10:24 AM / IP Logged
It sounds like the data wire is still disconnected. The cheating way to bypass the passlock was to start the car with the key and then cut the data wire and install a switch between the two wires. This would let everything opperate fine but it would leave the light on. I would double check the data wire, and then disconnect the battery for 15min. If the light is still on after you have done this then there is a problem with the passlock system and may need to go to the dealer.
  Craig.
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
