DEI 530t
dljbrla
Member - Posts: 23
Posted: October 21, 2002 at 10:00 AM / IP Logged
Please, can anyone send me the wiring diagrahm for the 530t window module. My dealer uninstalled it from my old truck and did not furnish any instructions or schematics on how to wire it up.
thanks,
Danny
Moderator - Posts: 12,488
Posted: October 21, 2002 at 11:23 AM / IP Logged
http://www.imagestation.com/picture/sraid31/p6ac05c85566ab7bed9138bf11139eae3/fd4d92de.jpg
dljbrla
Member - Posts: 23
Posted: October 21, 2002 at 12:24 PM / IP Logged
Thanks Jeff for the reply,
This is a good start, but I need to also know about the small (7) wires in the harness that plugs in the side of the unit. The dealer that uninstalled it cut them about 18" from the plug.
thanks again,
Danny
Dunbar
Member - Posts: 12
Posted: October 22, 2002 at 6:06 PM / IP Logged
Post your e-mail
djfearny2
Silver - Posts: 810
Posted: October 22, 2002 at 6:36 PM / IP Logged
the seven wires are as follow there is a white, white black, brown, brown black. orange, grey and a red and white,
listen ist easy white goes with green and brown goes with blue.
now there is a ground-black, red-pos, blue - motor side down #1, blue/black- motor side  down #2, green, motor side up #1, GREEN/ black motor side up #2
like i said the wire with strips goes with strips and the wires without are without  the blue and brown wire without strip go to the down side of drivers door. blue to motor side and brown to switch side. green and white wire is the up for drivers side green motor side and white switch side.  same thing for the passanger side blue /black and brown black down side of passanger and GREEN/ black and white black up side heavier guage wire goes to motor side . if you need more help hooking up email me and iwill get back to you
o yeah orange wire is negative trigger for up , grey wire is ground loop so all you have to do is trigger window once negative once on orange wire and the two connected together will loop and make the window go all the way up. RED / white negative trigger down off of a remote or something, let me know if you need any more help i did a 529 back and a 530 front in a car today. so it is fresh in my mind,
Jon
Installer/Help Technician
---coral springs florida---
Tuesday, July 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
