sound volume clifford G5/G4 siren
Mystic-rallye
Member - Posts: 20
Posted: January 06, 2005 at 11:43 AM / IP Logged
because my G4 siren of my avantguard 4 was broken I,ve fitted one of the G5 series (bought by a clifford dealer) but it seems like the arm/disarm sounds are less loud then the G4 series (in the same volume level).
is this because the battery is not full yet or is the G5 siren less loud????
greets mischa b
Mystic-rallye
Member - Posts: 20
Posted: January 06, 2005 at 3:36 PM / IP Logged
does somebody know??????
kgerry
Platinum - Posts: 3,455
Posted: January 06, 2005 at 4:04 PM / IP Logged
is it possible you had disengaged the "soft chirp" feature of your old siren?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Mystic-rallye
Member - Posts: 20
Posted: January 06, 2005 at 4:10 PM / IP Logged
no it,s in the same mode as the old siren I,ve checked it allready and have tried they other mode,s
Mystic-rallye
Member - Posts: 20
Posted: January 07, 2005 at 3:32 AM / IP Logged
does nobody know if the soft chirps of the G5 siren are at a lower volume then the one of the G4 series???
Mystic-rallye
Member - Posts: 20
Posted: January 07, 2005 at 11:55 AM / IP Logged
no that dound is much louder
kgerry
Posted: January 07, 2005 at 3:23 PM / IP Logged
with most Clifford sirens there is usually a loop you can cut on the siren if you want to increase the sound of the activation chirps....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
